How to install Linux under Virtual PC?
Postby Antony » Thu 11 Sep, 2003 11:52 pm
I tried installing Mandrake Linux 9.1 (x86) under VirtualPC 6 under Mac OS X 10.2.6, and I failed (three times).
The installation setup all went successfully, however, after installation, except the first time setup wizard, I can't boot up the Linux at all. The screen will stay at desktop wallpaper (no taskbar) and keep refreshing every few minutes. Nothing changes for few hours.
Are there any special settings I need to adjust when setting up a Linux environment under VirtualPC?
Or shall I install Yellow Dog Linux (based on RedHat) instead?
If installing Yellow Dog, I can't run Linux on top of OS X.
All sorts of help welcome.
PS, I know combining Mac OS and Linux into one section was a good idea... This is a good example.
Postby Edward » Fri 12 Sep, 2003 6:23 pm
This page explains how to install Red Hat 6.1 on a G4/450 running Virtual PC 3. It might be able to help you install Mandrake on yours.
UserAgent: Opera/7.11 (Linux 2.4.20-4GB i586; U) [en]
Postby DJGM » Fri 12 Sep, 2003 6:40 pm
I wouldn't try installing YellowDog Linux, as it is a full PPC compatible Linux distro that will
not start or run under any version of VirtualPC. Depending on your HDD, you would most
likely need to repartition it, causing your current Mac OS partitions to be lost.
Basically, when installing an x86 compatible Linux distro on VirtualPC, treat it as though
you were setting it up on an older PC (such as Pentium Pro) with a lower capacity HDD.
In my experience, it's best to try as many different, but compatible Linux distros as you
can get hold of. Try them, one by one, and stick with whichever works best for you.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.4.1) Gecko/20030906
Postby Antony » Tue 23 Sep, 2003 7:13 pm
There are reports from Australia broadband discussion board that Mandrake 9.1 (x86) on Virtual PC crashed all the time.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/85.7 (KHTML, like Gecko) Safari/85.5
Postby Edward » Tue 23 Sep, 2003 8:54 pm
Antony - Were you able to get it installed?
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Linux 2.4.20-4GB i586) Opera 7.11 [en]
Mac OS and Linux (on Virtual PC)
Postby Sandbender » Sat 11 Oct, 2003 2:23 pm
I have been around 95% successfull in installing Red Hat Linux 9 on Virtual PC 5.
I'm running 10.2.7 on a Powerbook G3 400Mhz.
All went well, with CD's auto ejecting etc. until the very very last step when I was asked to identify my monitor, on three occasions both the auto configure or my choice resulted in what appeared to be a log in screen rendered in 20 x 20 pixels, not to pretty.
The screens during the loading process worked fine.
I plan to try again when I have a copy of VPC 6
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/85 (KHTML, like Gecko) Safari/85
Sandbender
Postby keith » Mon 15 Mar, 2004 12:00 pm
i was wondering what the difference is between linux and all this mac stuff? i don't understand it very well, could someone please explain for me? My knowledge may be good in IWndoes but with a Mac i am totally lost.
Thanks
Keith.
KEITH
keith
gold member
gold member
Postby Mandrake » Mon 15 Mar, 2004 8:02 pm
Linux is a totally seperate OS to Mac OS X, they are based off different code bases and don't have a whole lot in common.
Postby Antony » Tue 16 Mar, 2004 1:29 am
keith wrote:i was wondering what the difference is between linux and all this mac stuff?.
There's no relationship between Linux and Mac OS, but there could be some.
If you talk about Mac OS (now called "Classic") prior to Mac OS :X: 10, there's no relationship between Linux and Mac OS (up to 9.2.2).
Now, Mac OS :X: is based on the open source code Darwin which is a variation (flavour they call it) of UNIX based on BSD 4.4 Lite, FreeBSD, NetBSD, and the Mach microkernel. Darwin is vary similar to FreeBSD (many said,) but better. FreeBSD is a flavour of UNIX.
Linux is an operating system designed to run on PC (i.e. x86) and to have the same strength as UNIX. In other words, a clone of UNIX.
So, that is the relationship.
What I tried to do (as mentioned in earlier posts), I was trying to install Linux and FreeBSD under a PC emulation software so I can run them under my Mac.
For more information about Macintosh's operating systems, please read this thread.
Postby keith » Tue 16 Mar, 2004 10:51 am
ok antony, thanks, that was a bit of a help
keith.
KEITH
keith
gold member
gold member
Postby Mandrake » Sat 27 Mar, 2004 8:28 am
I prefer VMware to MS Virtual PC, particularly because it runs on Linux, but I've installed SuSE 9, Redhat 9 and Xandros 2.0 under VMware with no difficulties. (Host OS is Windows XP Professional).
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7b) Gecko/20040314
Postby Antony » Wed 07 Apr, 2004 7:58 am
Mandrake wrote:I prefer VMware to MS Virtual PC, particularly because it runs on Linux,
Had VMware run under Mac :mac:, I would have bought a license of it. (If the price is reasonable.)
BTW, I finally installed Linux on Virtual PC :).
(Mandrake Linux 10.0 Community :tux: under Virtual PC for Mac, Mac OS :panther:)
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/124 (KHTML, like Gecko) Safari/125.1
So, do tell!
Postby cloetus » Tue 04 May, 2004 12:38 pm
I've been trying the network install, but it can't find VPC's NIC...
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.8a) Gecko/20040502 Camino/0.7+
cloetus
