7.1 Mail "Frame" Settings
Postby Strobe » Thu 09 Oct, 2003 7:22 am
Gday,
I have just installed Netscape 7.1, and done some wierd stuff with my profile, which results in the fact that im not using my orig prefs files.
The problem I am now having is when I set up the size of the frames and the fields/columns shown, the next time I start Netscape the settings have reverted to normal.
Anyone got a fix?
Thanks
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; T312461; .NET CLR 1.0.3705)
Strobe
Strobe
SOLVED
Postby Strobe » Fri 10 Oct, 2003 1:43 am
Helps when XUL.MFL, PREFS.JS, PREFS.BAK files aren't set to read only.
Hope this helps someone in the future...
Strobe
Strobe
Re: SOLVED
Postby Fulvio » Fri 10 Oct, 2003 1:24 pm
Strobe wrote:Helps when XUL.MFL, PREFS.JS, PREFS.BAK files aren't set to read only.
If your files are as read only, they must have been saved on a disk and copied from there. The xul.mfl file can be deleted, and will be recreated.
As for the pref files, if you are using a saved file, sooner or later you will run
into some problem, unless your preferences are identical to the content of the file.
