abook.mab corrupt
abook.mab corrupt
Postby Strobe » Fri 10 Oct, 2003 2:41 am
Hi again...
I just upgraded to NS7.1 and when I open Mail, it says that abook.mab and other mab files are corrupt.
How can i fix this? They worked fine previously. I can still view the files perfectly well in Notepad...
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0; T312461; .NET CLR 1.0.3705)
Strobe
Strobe
Re: abook.mab corrupt
Postby Fulvio » Fri 10 Oct, 2003 1:29 pm
Strobe wrote:Hi again...
They worked previously, but where did they come from?
Postby Strobe » Fri 10 Oct, 2003 6:02 pm
I was not using this computer for some time, and i copied my mail folder onto a cd before i stopped using it so i could check my email on another machine.
I copied the mail to another machine and created a new profile and got taht all working well...
When it came to using this machine again, i now had two versions of my profile. Before i even ran NS on this again, I installed 7.1. Then i created a new profile and put the mail folder from the other comp i was using in, and the profile info, etc. from the old profile on this comp. Including the abook and other MAB files.
Didnt really have a problem with getting the email to work again, but the address book just wont load...
Hope you can understand this.
Strobe
Strobe
Postby Edward » Sat 11 Oct, 2003 7:17 pm
When you copied the files to the CD, it's possible that either the CD did not burn correctly, or you had a bad disc, resulting in the good file becoming corrupt when it copied to the CD.
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.4) Gecko/20030624 Netscape/7.1
Postby Strobe » Sat 11 Oct, 2003 9:27 pm
No, any abook file i try doesnt work. Except for the ones netscape creates after it says mine are corrupt.
Strobe
Strobe
Postby Strobe » Tue 14 Oct, 2003 11:53 pm
I still have the problem.
Anyone got any tips or guides to importing Address books?
Strobe
Strobe
Postby Fulvio » Wed 15 Oct, 2003 11:32 am
Strobe wrote:I still have the problem.
The only reasonable way to "import" an address book, is to export it, from the Address Book, as a .ldif file. When I said, where do the files come from, I should have been specified, in which version were they?
There is a bunch of Address Book information here: http://home.att.net/~cherokee67/index6.html#7mailab
