I have some problems with the PDF and Excel attachments. Some users send mails to me with PDF files attached, and I am able to open the files upon reading mails.
The problem is that some excel attachments are mis-handled by the PDF pluggin. Excel files are opened by the Acrobat reader.
I checked and found out that Netscape perceived that the excel files are Octectstream/PDF files, so I make change at helper application, by removing the octectstream/PDF out.
Later on, when mails arrive with the PDF and excel attachements, netscape prompts to save or open the attachments. This is annoying. Sometimes it does ask, but sometimes it does not.
Is this because the different PDF file versions sent by the senders? How can I solve this problem? What is Octectstream/PDF? Why did netscape (or acrobat) mishandle the file type opening.
Thanks for helping.
Best regards,
Thavee
