About:config Question
Postby szale9001 » Tue 21 Oct, 2003 9:27 pm
I was lookin at my about:config screen and i saw an AIM line pertaining to the away message.
aim.away|hidewindow|default|boolean|false
What does this mean. If I change it to true, will it hide my IM windows when I am away. I just want to know so I don't screw anything up. Oh, and on a separate note. My Radio Netscape has...disappeared. It was installed and the nsradio.zip file is inside the Installation files. I want to create a shortcut, but I don't know the path.
Thanx a lot.
szale9001
Postby Fulvio » Tue 21 Oct, 2003 10:17 pm
I would not even try to guess what that line means. There is more to it than the hidewindow part.
Things disappear off and on.
If it is only the shortcut which disappeared, and you have Radio@NetscapePlus, it should be : Program Files|Radio@NetscapePlus|
Program|radio@netscape.exe I don't have WinXP, but it should have that path.
Postby frease » Sun 02 Nov, 2003 6:07 am
How do I change the about:config settings?
In Firebird, all I have to do is double-click on the value and I am able to change it. However, in Netscape, double-click does has no response.
Thanks in advance.
frease
Postby Antony » Sun 02 Nov, 2003 6:36 am
Double clicking works for me (NS 7.1 in WinXP).
Otherwise, try context click* and select modify.
* commonly known as right-click.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/85.7 (KHTML, like Gecko) Safari/85.5
Postby frease » Sun 02 Nov, 2003 6:54 am
I have tried all sort of "clicks" but still there is no response.
frease
Postby orizng » Sun 02 Nov, 2003 9:12 am
frease wrote:I have tried all sort of "clicks" but still there is no response.
You must run NS 7.1 to do it, not 7.02
Whatever,whatever,have a nice day.
orizng
Postby frease » Sun 02 Nov, 2003 9:15 am
Thanks, I guess I'll have to do without that because I cannot upgrade to 7.1 as it causes resource drainage.
UserAgent: Mozilla/5.0 (Windows; U)
frease
