Open last visited
Open last visited
Postby frease » Sun 02 Nov, 2003 6:51 am
Is there any way to get Netscape to open last visited tabs. I chose Open Last Visited under Preferences but it does not seem to work.
Pls excuse me if there is a similar thread on this. I has did a search on
"last open tabs" but found no threads that can answer my query.
Also, my Preferences do not display correctly. The right side is cut off. I am using the default Modern skin. See pic below:
Thanks in advance.
frease
Postby orizng » Sun 02 Nov, 2003 8:55 am
I think this is what you want
http://www.pikey.me.uk/mozilla/
search for "session saver",
or click this:
http://www.pikey.me.uk/mozilla/extensio ... nsaver.xpi
I know it works well with Firebird, but never try to use it under Netscape 7.1
I personally dont like this.
Whatever,whatever,have a nice day.
orizng
Postby frease » Sun 02 Nov, 2003 9:09 am
Thanks but does it work with Netscape? If yes, does all Firebird extensions work with Netscape?
UserAgent: Mozilla/5.0 (Windows; U)
frease
Postby orizng » Sun 02 Nov, 2003 9:15 am
frease wrote:Thanks but does it work with Netscape? If yes, does all Firebird extensions work with Netscape?
You must try yourself to find out.
Not all extensions for FB can be used for Netscape/Mozilla, but some of them do.
orizng
Postby frease » Sun 02 Nov, 2003 9:52 am
I tried, it didn't work. Thanks for the help :)
frease
Postby Edward » Sun 02 Nov, 2003 10:03 am
Just out of curiosity, I opened three tabs, one with SD, and two news sites. Preferences changed to open with Last Page Viewed.
Mozilla 1.5 (Linux) was closed, then reopened. It displayed a blank page.
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.5) Gecko/20031007
Postby orizng » Sun 02 Nov, 2003 5:30 pm
frease wrote:I tried, it didn't work. Thanks for the help :)
No, I tried also, it workds
First , installed it
Then, change your homepage setting to "last visited" in preference.
But at the same time, even without this extension, last visted also works for me in NS 7.1.
You may want to try creat a new profile?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.6a) Gecko/20031029 Firebird/0.7+
orizng
Postby Edward » Sun 02 Nov, 2003 5:46 pm
In Mozilla 1.5 (Windows), what opens afterwards, is the last page retrieved, regardless of which tab it is on. The other tabs are dropped.
Registered users: Exabot [Bot], Google [Bot], Yahoo [Bot]
