Boot Problem :(
Boot Problem :(
Postby Andrei » Wed 12 Nov, 2003 5:48 am
Okay here is a little story:
I had Linux and Win 98 installed at one time , i fdisked Linux partition and didn't bother removing Linux booter , now something happened and i have LI message at the boot up and no procedures follow so i can't boot up to windows.
I tried going to dos throgh recovery cd and using fdisk /mdr command but it said that /mdr is invalid parameter.
So now i am stuck , i would appreciate it if someone can help me with this.
Cheers
Andrei
Postby Mandrake » Wed 12 Nov, 2003 8:43 am
I'm not sure that you can use a recovery CD, but if you Google for a Windows 98 startup disk, you can boot from that and run the "fdisk /mbr" command and remove LILO and replace it with the standard boot manager for Windows.
UserAgent: Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)
Postby Andrei » Wed 12 Nov, 2003 7:26 pm
Well i found 98 boot disk and fdisked mbr and now it says Operating System not found :( . What should i do now ? (i think i have to restore the original 98 mbr or something like that but don't know how)
Andrei
Postby DJGM » Wed 12 Nov, 2003 7:35 pm
If this was a problem I was experiencing, I'd attempt to re-install Windows at this point.
No need to reformat the HDD though. I would do what is referred to by Microsoft as an
"in-place upgrade", which means re-installing Windows over an existing installation.
Just put your Windows CD in your CD drive, restart the PC, and follow the prompts.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.4) Gecko/20030624 Netscape/7.1 (DJGM-i.net)
Postby Andrei » Wed 12 Nov, 2003 8:51 pm
Well i guess i'll put hd in my other , back everything up and reinstall win.
Thanks for your help tho.
Andrei
Postby Andrei » Wed 12 Nov, 2003 9:29 pm
Apperantly my windows partition wasnt active , therefore mbr didn't see it. I just made it active using fdisk and it's good now.
Andrei
