7.1 Won't Launch in XP
Postby rock5025 » Sun 16 Nov, 2003 5:54 pm
Alright folks, help! I have uninstalled/reinstalled 7.1 three times using Ramona's tips. The last time I diligently searched for the GRE files that she suggested removing but could not find following the file path name given. I get a clean install of the 7.1 streamline w/no error msgs but no go on any URLs or launch. I have read all the messages and gone to several FAQ sites. Essentially, Ramona's tips are the most clarifying but no luck. I am seriously considering uninstalling 7.1 and NComm 4.79 and going to IE6. I don't need this grief over a blooming BROWSER!!
UserAgent: Mozilla/4.79 [en]C-DIAL (Windows NT 5.0; U)
rock5025
Postby Edward » Sun 16 Nov, 2003 6:32 pm
I don't use XP, but have you tried a clean install of 7.1?
Uninstall the existing 7.1, delete the Netscape 7.1 directories afterwards, reboot, and reinstall from scratch.
DISCLAIMER: Deleting all of the relevant directories, including the profile directories, will also remove the profile that had been created.
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.5) Gecko/20031007
Postby Mandrake » Sun 16 Nov, 2003 7:16 pm
Uninstalling 7.1 and 4.7 is easy (Why would anyone want 4.x in XP is beyond me though!), then removing the \Program Files\Netscape directory will remove every last bit of Communicator and it's profile, and 7.1.
Deleting the 7.1 profile is a little more complicated though. First open My Computer, then go into Tools, Folder Options. Enable the viewing of hidden files/folders. Then go into C:\Documents and Settings\Windows Login-name\Application Data\ - you should see a folder called 'Mozilla', delete that folder and everything in it. Then disable viewing of hidden folders and your 7.1 profile is gone.
Now that they are gone, you can try re-installing 7.1, or you could download Mozilla 1.5 (Just like Netscape), or you could try Mozilla Firebird. I've found that if someone is having problems with Mozilla or Netscape, rather than troubleshooting for ages why the browser won't work, you can just use Firebird and sidestep the issue. You can get Firebird 0.7 (latest version) with the installer from here. Then you just have to install Flash, Java and all that stuff.
