System Requirements of Mac OS X Jaguar
Postby hartlandcat » Tue 18 Nov, 2003 5:21 pm
Can anyone tell me how much hard disk space Mac OS X Jaguar takes up? It's no longer listed on the Apple website, the required hard drive space is missed off its page at Amazon, and everywhere else I've found have had varied results.
Thanks! ^_^
UserAgent: Mozilla/5.0 (Macintosh; U; PPC; en-US; rv:1.0.2) Gecko/20030208 Netscape/7.02
Mac OS X Panther :: iBook G4
My SF Site | My Browser Reference Chart
hartlandcat
Postby DJGM » Tue 18 Nov, 2003 7:11 pm
Mac OS X requires 1.5GB of HDD space for the full installation, but there are some things in
the installation that you probably won't need or want or install. You'll get a chance to pick
and choose the optional Mac OS X software components you wish to install.
For instance, if there's no printer with your iMac, you won't need to install the printer
drivers. IIRC, there are a numbers of international language modules/components
you probably won't want (or even need) to install.
When I installed Mac OS X for the first time, the optional components I choose to
install took up just under 1GB of HDD space. I choose not to install any of those
printer drivers or any of the international component gubbins.
But when I upgraded to Mac OS X 10.1 (from 10.0) I ended up gaining just over 100MB
of HDD space, instead of losing any. The Mac OS X 10.1 installer disc actually only
replaced older components with the newer updated versions. I think the extra
hard disk space gained may have been the installer cleaning out obsolete
temporary files that were no longer needed
After the upgrade to 10.2, I regained about 20MB of HDD space. Again, the 10.1
installer CD only replaced older components with newer versions, and cleared
out obsolete temporary files that were no longer needed
After my eventual upgrade to Mac OS X 10.3, I probably won't regain any diskspace!
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.4) Gecko/20030624 Netscape/7.1 (ax; BDP)
Postby hartlandcat » Wed 19 Nov, 2003 12:54 pm
Thanks! ^_^ I was a bit concerned because Dabs.com said that it required 3GB of hard disk space. But I'll definately upgrade to OS X now. I have a 6GB hard disk, and I'm using about 2GB of it at the moment, but I'll be able to get rid of some of my OS 9 programs when I upgrade to OS X.
hartlandcat
System Requriement for Jaguar
Postby Antony » Wed 19 Nov, 2003 8:17 pm
This is the official System Requirement for Jaguar :jaguar:
Apple Store wrote:Requirements
Power Mac G3 or G4, iMac, eMac, PowerBook G3 or G4, or iBook computer with 128MB of physical RAM.
Mac OS X v10.2 supports all video cards shipped by Apple on Mac OS X-compatible systems. Quartz Extreme functionality is supported by the following video cards: NVIDIA GeForce2 MX, GeForce3, GeForce4 MX, or GeForce4 Ti; Any AGP-based ATI RADEON card. A minimum of 16MB VRAM is required.
QuickTime Pro functionality requires a QuickTime 6 Pro key. The QuickTime 5 Pro key will not work after this software is installed.
DVD Player requires a DVD-ROM equipped Macintosh with built-in FireWire.
Features or content provided by Sherlock may change or be discontinued at any time.
The original PowerBook G3 and processor upgrade cards are not supported.
Postby phatvspec » Mon 24 Nov, 2003 11:39 pm
i would recomend 256MB of memeory although people now get 512 to be ok for upgrades and so forth.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.5) Gecko/20031007
phatvspec
Postby hartlandcat » Tue 25 Nov, 2003 12:41 pm
Yes, I'll probably add more RAM soon (if I can find how to open the thing up! ^_^)
Anyhow, I've just got Mac OS X Jaguar from Ebay!! Should be arriving sometime over the next few days.
hartlandcat
Postby phatvspec » Tue 25 Nov, 2003 12:59 pm
since u have a tray loader i am guessing u have an iMac and to add memory or ram if you turn it over while the machine is off and unplugged you should see a lil scre in the middle. Like you can see where there is an area that will come out, should be 6" by 3" or so with a screw in the middle. If you unscrew that, that is where it goes.
phatvspec
Postby hartlandcat » Tue 25 Nov, 2003 1:03 pm
Thanks! ^_^
hartlandcat
Postby DJGM » Tue 25 Nov, 2003 8:03 pm
Here's the guide I've referred to when I've upgraded my old iMac internally . . .
Upgrading an iMac
When I wanted to upgrade my iMac's RAM and HDD, this guide was a godsend!
Here's another informative guide you may find quite useful . . .
Keeping an iMac Current:
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/85.7 (KHTML, like Gecko) Safari/85.5
