by Fulvio » Tue 16 Dec, 2003 12:54 pm
ADG96 wrote:Hello,
Is there a way to get rid of the netscape webmail from showing up in aim..I want to use OE as the one and only default mail..
Thank you...
I have never heard that it was even possible to do anything with webmail in
AIM. You do need the Netscape version of AIM, in order to set up Webmail in
Netscape. and you have to do it. It is far from automatic.
And, as Antony said there is no way to get Netscape Webmail in OE.
Long ago, I tried it, and I still have an Identity with my webmail username, which I cannot use, nor remove because I can't remember which password I used.
