Address cards cannot be delted from lists
Postby trekman » Mon 23 Feb, 2004 2:30 am
I have Netscape 7.02 & have been using Netscape since the 4.76 days.
Here is the problem:
I can create address cards
Then I create new lists
Then I drag & drop my address card into the list
After doing this a dupicate of that address card is created in the main personal address book list
So for every list that I drag & drop a card a duplicate card is created
If I delete the new address card in the main list then that list will no longer accept any new address cards
If I delete an address card while in a list it also locks up that list so it will no longer take any new cards
I have tried reinstalling Netscape 7.02
I have tried compacting folders
No change
I did a search for address book & I just read a recent post that sounds similar but not the same, so I still looking for an answer
Thanks
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.0.2) Gecko/20030208 Netscape/7.02
trekman
Postby captjlddavis » Mon 23 Feb, 2004 2:09 pm
trekman,
Does this happen with ALL lists or only a list in a particular addressbook ?
regards:captjlddavis
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.6) Gecko/20040113
captjlddavis
gold member
gold member
Postby Fulvio » Mon 23 Feb, 2004 3:54 pm
Chris,
I did not have your problem, but I created an address book, and then New|Mailing List. I added the addresses, and when I closed the list, I tried to delete the addresses which had shown up. And, the contents of the list disappeared, so I put them back, and I closed the list. Then, I double clicked on the list, and entered another e-mail address, and had no problem entering it, but another entry in the Address Book had popped up. Finally, I deleted the list, and had to select the appropriate Address Book to start again, and I repeated the process. And, a list was there.
I don't know if the version of Netscape (or Mozilla) matter, but considering the other thread http://sillydog.org/forum/viewtopic.php?t=4784 I would say that there may be some misunderstanding here and there. How do you try to add a list?
Postby trekman » Mon 23 Feb, 2004 7:45 pm
It happens with ALL lists. The list I created yesterday. The last from last year.
It even happened with my old email list before I lost it & created a new one. I think I even reinstalled 7.02
I add to a list by dragging the highlighted card over to the list in the left column. I then can open the list & the card is in the list. When I return to the main address book list there are now tow of those cards. If I add the same card to different list, there will now be three cards in the main list.
If I delete any of these cards, the list that that card was connected to will no longer accept any new cards. You can drag & drop them but when you open the list it will not be added & there will not be a duplicate card created as before.
trekman
Postby captjlddavis » Mon 23 Feb, 2004 9:03 pm
trekman,
To say that the address book in NS/MOZ is lacking would be an understatement.
I have been able to replicate some of your and others problems in NS 7.02-7.1 and Moz up to 1.6f.
the addressbook is based on a propietary format:
<mdb:mork:z v="1.4"/>
The workings of which are a closely guarded secret ?
I did a bug search at:
http://bugzilla.mozilla.org/
for:
address book
The list bogles the mind. Long boreing reading with little useful information.
But they are working on it.
I can give you some of actions that produce the problems, but not many solutions:
Duplicate entries in parent book:
If you Drag & Drop from one "list" to another "list" a dupe entry may appear in the parent book.
If you Drag & Drop from parent book to multiple lists within the same book, Duplicate entries may appear.
If you delete a duplicate entry from a book, it may disable the list and have unexpected results.
You can not determine which dupe entry goes with which list (porperties are the same).
In short I can not give you any real answere or fixes. If you do not do any "fancy" manueuvers - it seems to be adequate. Your defnition of "fancy" may differ from mine.
Sorry I can not be of greater assistance. It does look like the good people at Mozilla are aware of the problems and are working on solutions.
Please check:
Address book
Though I do not cover everything, it does give some idea of how I think it works.
captjlddavis
gold member
gold member
Postby trekman » Mon 23 Feb, 2004 11:09 pm
captjlddavis
You hit the nail on the head. You have described my problem exactly.
Hope they come up with a fix & I hope it allows users to then delete from existing address books without having to recreate the whole address book & lists in the new version
trekman
Postby ChrisI » Tue 24 Feb, 2004 1:09 am
This was a display bug that was fixed in April 2003. If you double-click on the address book list, you'll see what's really in your list. You need to upgrade your browser to Netscape 7.1 or the latest Mozilla.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7a) Gecko/20040219
Chris I
Please do not send me tech support questions privately.
ChrisI
Postby captjlddavis » Tue 24 Feb, 2004 1:34 am
Chris,
Thanks for the reply, Delete seems to work OK, The duplicate entry problems still exists in Moz 1.6f when you D&D from one list to anotherlist.. Also D&D from Book to list in another book.
IMHO there are still problems with the Abooks due to mork:mdb - Bug reviews show that they are known and in the works.
Regards:captjlddavis
captjlddavis
gold member
gold member
Postby trekman » Tue 24 Feb, 2004 12:44 pm
Chris I
Are you saying that 7.1 will fix my problem?
captjlddavis
Are you running 7.1?
trekman
Postby captjlddavis » Tue 24 Feb, 2004 3:22 pm
trekman,
I am running win98se - with various NS/MOZ versions.
NS 7.1 has a resource leak that some find unbearable. Moz 1.6f is,IMO, stable. The delete problems as stated by ChrisI "appears" fixed - but the "multiple data entries" seem to still be present in the addressbooks.
Hope this helps.
captjlddavis
gold member
gold member
Postby trekman » Tue 24 Feb, 2004 8:53 pm
captjlddavis
What is a resource leak?
Thanks for your comments
trekman
Postby captjlddavis » Tue 24 Feb, 2004 10:07 pm
trekman,
Short answere - resource leak -
A program that does not release system resources when they are no longer needed:
You can do a "google" for "resource leak netscape"
It is covered all over the place.
Hope this helps.
captjlddavis
gold member
gold member
