"Unable to write mail to the mailbox" - ???
Postby Dick » Tue 29 Jun, 2004 5:01 pm
When i try to download my new messages i get the message:
Unable to write mail to the mailbox. Make sure the system allows you write prevelages, and you have enough space to copy the mailbox
What the heck i have over 15GB free space on the drive my documents&settings folder is. I took a look in my account in "local settings\mozilla etc" in my e-mail folder. Although my trash is empty, there is a big file called "trash" that was like, 500 MB or something. Sometimes it takes an age to load the trash folder even when it appears empty in the mail program.
I use:
Netscape 7.1
P4 1.7 ghz
512 ram
windows xp home
Edited by Moderator to remove curse word
Dick
Postby Ramona » Tue 29 Jun, 2004 5:29 pm
Dick,
Compact your folders, and then try downloading your Mail. If no joy, then with Netscape and Quick Launch closed, navigate to your Mail folder, and delete all files with an MSF extension. Don't delete the files without the MSF extension, as they contain your mail. See: Profiles Folder Location.
Even though you have emptied your Trash folder, those files still remain in the folder, on the HD, until the Mail is compacted. Open the Trash folder in Windows Explorer before compacting, and you can see all the files you thought were gone...
Let us know if you continue to have problems.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7) Gecko/20040616
Postby Dick » Thu 01 Jul, 2004 3:42 pm
Sweet! It worked! Thanks!
Dick
Postby Ramona » Thu 01 Jul, 2004 3:54 pm
Hi Dick,
That's great, and you're most welcome!
us too
Postby architectmississippi » Fri 09 Jul, 2004 10:59 am
We are also getting this error but the deletion of .msf files has not helped. We use a unix server and are using netscape 7.1 on windows nt and xp machines. Sometimes, using a newer faster machine can download the problem mail, but sometimes not. The mail that it hangs up on always has an attachment but the size does not seem unreasonable usually. The last one was 364k in size. Before this started, we could routinely download attachments up to 10Mb easily.
We are wondering if this is an issue translating the mail from the unix format in /var/mail to the netscape format? But if so, we have no idea what to do about it.
Any Ideas?
Pamela
Postby Fulvio » Fri 09 Jul, 2004 12:04 pm
I don't know if the unix server is the problem. What is not clear to me is if you are having problems downloading mail without even looking at it, or is the problem after you got your mail, when you want to download the attachment. At that point, it is no longer a mail, but rather a Download issue. http://home.att.net/~cherokee67/ns71cantdownload.html
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7) Gecko/20040707 Seabunny/0.9.2
Postby akbash » Fri 09 Jul, 2004 12:52 pm
architectmississippi - There is a bug in all Netscape releases to date which causes the client to hang while retrieving a message that's malformed in a certain way (it's bug 166111 if you're interested in the details). The troublesome messages have line endings and message termination sequences that are out-of-spec in a way that Netscape mail doesn't expect. This sounds very much like the problem you're seeing.
The hang can be "fixed" case-by-case by logging into the mail server by hand and clearing out the problematic message. It may be fixed permanently by updating the server to a version that doesn't create out-of-spec messages, if such an update is available. It can also be fixed by updating the mail client to a version that isn't confused by the bad message.
This bug was fixed in Mozilla, the program Netscape 6 and 7 are based on, last March. As I mentioned, no Netscape mail client has been released since then. However the bug is fixed in Mozilla 1.7. You could update to Mozilla 1.7 or wait for the upcoming Netscape 7.2, due to be released "any day now," though I'd be prepared to hold my breath for a month or so.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8a2) Gecko/20040704 Firefox/0.8.0+
akbash
Thanks
Postby architectmississippi » Fri 09 Jul, 2004 2:42 pm
I guess we'll see what Netscape 7.2 brings.
oy!
Thanks!!
Pamela
Postby lidaray » Sat 10 Jul, 2004 12:17 am
hello, I have this same problem and have tried compacting the folders, deleting old messages, and manually deleting the *.msf files. I have also rebooted the machine several times in this process. All to no avail.
This account worked well until mid-evening two days ago. I am running Windows XP Pro and the only thing I have "changed" around the time this message started appearing was that I 1.) deleted several hundred emails from my inbox(It was not unusual for my account to have this many messages), and 2.) cleared my cache & cookies in IE while also running Netscape. I don't see how that would be related though.
I have a large number of subfolders in my netscape mail where I store all relevent info for my clients and I would really :!: hate to have to move to Outlook.
lidaray
Postby akbash » Tue 28 Sep, 2004 9:45 pm
This doesn't exactly match the problem description of anyone in this thread, but I wonder if you're seeing some variant of the problem described in http://sillydog.org/forum/viewtopic.php?t=6209.
Mozilla 1.6 was known to choke on certain malformed messages that some mail servers occasionally delivered. This sounds a great deal like your problem, except that the issue I'm thinking of generally showed an error alert: "Unable to write mail to the mailbox."
While this may not be exactly your problem, it is fair to say that Mozilla 1.6 was known to have issues with certain messages from certain servers. This bug (and many others, including some serious security flaws) is supposed to have been fixed (though I've heard reports to the contrary) in Mozilla 1.7.3, Netscape 7.2, and Thunderbird 0.6. It should help to upgrade. It may even solve your problem.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.3) Gecko/20040928 Firefox/0.10
akbash
Unable to write to mailbox
Postby jcmchesapeake » Sat 05 Mar, 2005 2:24 pm
Hhhhmm.
I've search for "*.MSF" files or folders - found none.
I've compacted my email folders in Netscape 7.1
I'm still getting the error. Any other suggestions out there?
Thanks, John
jcmchesapeake
Postby Fulvio » Sat 05 Mar, 2005 4:19 pm
What kind of mail accounts do you have. No need for details. Just the kind, or what is after the "@"?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8b) Gecko/20050217
Unable to write
Postby jcmchesapeake » Sat 05 Mar, 2005 5:18 pm
My email is [username]@cox.net. I'm using Netscape 7.1 email. There is one email that always gets transmitted into my inbox folder. The title of this SPAM email is: "VERY STRANGE OUTGOING PERSON RIGHT HERE egypt".
jcmchesapeake
Re: Unable to write to mailbox
Postby Alice » Sat 05 Mar, 2005 6:45 pm
jcmcheaspeake wrote:Hhhhmm.
Thanks, John
You'll need to change your Windows settings to enable viewing of hidden files and folders in order to see the xxxxx.MSF files (Inbox.MSF, Sent.MSF etc) inside the HIDDEN ...Application Data\Mozilla\Profiles"profilename"\xxxxxxxx.SLT\MAIL"mailserver" folders. For default profile locations, see: http://www.holgermetzger.de/pdl.html
From any Windows folder or My Computer, select Tools > Folder Options > View > select show Hidden Files and folders.
You'll also need to enable "Search hidden files and folders" in the Search window, under More Advanced Options if you're trying to find the *.msf files using the Windows search feature.
Once you find the MAIL"mailserver"\xxx.MSF files, such as Inbox.MSF and Sent.MSF ... delete ONLY those xxx.MSF files, no other files. Do all this with Netscape closed.
However, since you've noticed a strange piece of SPAM reappearing in your inbox, the first thing I would try would be to REMOVE all SPAM from the mailserver, using your ISP's WEBMAIL interface, as suggested earlier in this thread and in the bugzilla report, http://bugzilla.mozilla.org/show_bug.cgi?id=166111
Unable to write the email to the mailbox
Another possible solution, if you've already deleted the Netscape profile's .msf files and removed spam and other unwanted mail messages from the mail server (or if you've used another mail program to download ithe mail):
Close Netscape 7.xx completely.
Open the profile's ...\MAIL"pop.mailserver" folder.
Rename the Inbox(no extension) file to Oldinbox and delete the Inbox.msf file. When the Netscape Mail window is reopened you should see a new empty Inbox folder and a folder named Oldinbox.
For more ideas see:
http://sillydog.org/forum/viewtopic.php?t=8117
Unable to write email to mailbox.....
http://sillydog.org/forum/viewtopic.php?t=1853
Unable to retrieve email
Halleluja, hallelujah!
Postby jcmchesapeake » Sat 05 Mar, 2005 8:43 pm
Dear Alice and Fulvio,
Something (I wish I could tell you exactly what) worked!
I've got my mail downloading protocol back.
I did go to MS Outlook and download some files (including the SPAM file I mentioned) and that may have "fixed" the problem. But, then again, I tried other suggestions, as well.
Thank you, thank you!
jcmchesapeake
