4.79 or 4.80 will not work anymore
Postby Nuckle » Thu 22 Jul, 2004 8:33 am
Recently I had a power surge and when I brought my computer bak up netscape quit working. Every time I clicked on any of the executables it would want me to create a new profile. After many attempts I completly uninstalled and reinstalled both 4.79 and 4.8 with the same thing happening again. It seems to just never allow the profile to stick. The browser will not open at all nor will the e-mail. Any help would be greatly appreciated.
Nuck
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.0.3705; .NET CLR 1.1.4322)
Nuckle
Postby Ramona » Sun 25 Jul, 2004 6:13 pm
Hi Nuckle, and welcome to the Forum!
Backup your Users folder
Close Netscape, and Open Windows Explorer
Rename the NSREG.DAT file to XNSREG.DAT
(This is the Netscape Registry, and may be corrupt)
The file is located in C:\WINDOWS
Restart Netscape, and the NSREG.DAT file will be rebuilt
The Profile Manager will prompt for a new Profile
Use the same name as the existing Profile, and it should be recognized
Multiple Profiles can be restored the same way
HTH,
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.1) Gecko/20040707
Postby Nuckle » Mon 26 Jul, 2004 7:01 am
Thanks Ramona! That fixed it. It worked just like you said. Thanks again!
Nuck
Nuckle
Postby Ramona » Mon 26 Jul, 2004 8:11 am
Hi Nuck,
Glad I could help!
Return to Communicator
