Netscape 7.2 Released (User Report and Feedback)
Re: Missing SidebarPanel.xul Message
Postby Alice » Fri 27 Aug, 2004 9:27 am
Roy wrote:The missing SidebarPanel.xul message is displayed when installing the BASE version of Netscape 7.2 which does not include the "Component Instant Messenger" (NIM.xpi) or when creating a custom install and not including it.
The missing file is located in the AIM.JAR in the NIM.XPI file.
So did you fix the problem?
http://ilias.ca/netscape/troubleshooting/#sidebar says:
Missing sidebarpanel.xul
Download sidebarpanel.xul and copy it to Netscape/chrome/packages/aim/
If you don't have a C:\Program Files\Netscape\Netscape\chrome\packages\aim folder, create a folder named packages in the Chrome folder, then inside that, create a folder named aim, then place the SidebarPanel.xul file inside.
From http://bugzilla.mozilla.org/show_bug.cgi?id=98519
------- Additional Comment #9 <snip> 2001-09-07 12:08 PDT [reply] -------
Re build 2001090603 and last several releases:
I created a text file, named it SidebarPanel.xul and stuck it in the
.../packages/aim folder, and gosh, the message did not appear. As a note, the
.../pacakages/aim folder did not exist.
S/NETSCAPE/MOZNIGHTLY/BIN/chrome/packages/aim/SidebarPanel.xu
Does not appear - had to be created.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.2) Gecko/20040803
Send Your Feedback to Netscape
Postby goGecko » Sun 29 Aug, 2004 10:02 pm
I would recommend that users at sillydog also share their 7.2 feedback with Netscape. A survey is located here:
http://wp.netscape.com/browsers/7/feedback/survey.html
Thanks for taking the time to share your experience with Netscape.
goGecko
Not now... too late
Postby James » Wed 01 Sep, 2004 10:50 am
I tried repeatedly to Submit my survey but it wouldn't take. It kept telling me to Go Back and complete it. Well... not now, folks. I spent a fair amount of time trying to honestly answer the questions and I've no intention of wasting any more time. Sorry. :cry:
Re: Not now... too late
Postby profman » Wed 01 Sep, 2004 3:09 pm
James wrote:I tried repeatedly to Submit my survey but it wouldn't take. It kept telling me to Go Back and complete it. Well... not now, folks. I spent a fair amount of time trying to honestly answer the questions and I've no intention of wasting any more time. Sorry. :cry:
It worked for me just now.
Postby Wellander » Wed 01 Sep, 2004 3:22 pm
I have submitted it twice.
UserAgent: Mozilla/4.0 (compatible; MSIE 5.0; Windows 98; DigExt)
Wellander
Postby Wellander » Fri 03 Sep, 2004 7:32 pm
I like 7.2 very much even though it took along time to see.
Wellander
Postby Alice » Sun 05 Sep, 2004 5:38 pm
For anyone trying to run Java applets in Mac OSX 10.1.5 using Netscape 7.2:
I installed Netscape 7.2 on my husband's Apple Ibook running Mac OSX 10.1.5 and was disappointed to see that Java applets would not run, even though they did in Netscape 7.0.
Netscape 7.2 was the only other Gecko-based browser installed on my husband's Ibook so this is the first time I came across this problem. I was looking around for a solution and I found the Camino 0.8.1 release notes which mentioned
Java issues
* If you are running Mac OS X 10.1.5, you need to download the MRJPlugin to run java applets.
with a download link to:
http://ftp.mozilla.org/pub/mozilla.org/ ... JPlugin.gz
I decided to try that download, even though I didn't have Camino installed at the time. After copying the MRJplugin.plugin file to the Library/Internet Plugins folder, Java applets now run in Netscape 7.2.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.7.2) Gecko/20040804 Netscape/7.2
net 7.2 install? Running 7.1 Streamline. Windows 98 on Lapt
Postby jscott » Sat 11 Sep, 2004 1:26 pm
If I download Net 7.2 can I keep my 7.1 Streamline running without loosing anything ? Will 7.2 then be primary or can they run at same time ? Would like to downlaod 7.2 and try for time, but would like to keep 7.1 running until I know that 7.2 is good. SCOTT: JHSCOTT@SPRYNET.COM
If possible to have both running, please explain how to load so that I don't loose one.
jscott
It's possible, but not recommended
Postby goGecko » Sat 11 Sep, 2004 4:46 pm
You can have Netscape 7.1 Streamline and 7.2 installed at the same time, but it is quite a hassle. I would recommend that you uninstall 7.1 Streamline and then install 7.2. If you insisit on keeping 7.1 Streamline then here are some instructions:
1. Go to start...programs...netscape...profile manager
2. Choose "Create Profile."
3. Click Next.
4. Call the new profile something like netscape72
5. Click Finish
6. Download Netscape 7.2 Setup
7. When 7.2 asks where to install, do NOT use the default location. Place 7.2 in a different folder such as netscape72 or something.
8. After setup, open 7.2 with the profile "netscape72." Use the profile "default" in 7.1 Streamline
9. Right-click on the shortcut to 7.2 and choose properties.
10. Add the following to the end of the command line. -P netscape72
11. Click okay and do the same to your shortcuts for 7.1 Streamline but instead add -P default instead.
Note that you cannot run 7.1 and 7.2 simultaneously (unless you try another long procedure). You can only have 7.1 or 7.2 open at the same time.
goGecko
Postby OneVoice » Wed 15 Sep, 2004 5:37 am
I just got the new Netscape 7.2 a few days ago and it's pretty much everything I enjoyed about Mozilla and more! I really like the improvements all round. It's a great job done by NS that can only get better. :)
OneVoice
i dont like it (n'scape 7.2 that is)
Postby stew2004 » Thu 30 Sep, 2004 4:28 am
i prefer the good ol multi column bookmarks. they should have the option there for this. that way those who like the scrolling look will be happy, so will the ones who like multi column.
is there a tweak to do this? like a simple reg tweak to get rid of the scrolling menu in windows?
UserAgent: Mozilla/4.8 [en] (Windows NT 5.0; U)
stew2004
Control Not available in URL
Postby sachinonnet » Fri 24 Dec, 2004 8:51 am
it's great to use Netscape 7.2 but whenever i open new tab control not available in URL / Address bar. i has to use Mouse or Keyboard for this. in New mozilla i won't found this problem and it's also an greate browser to use. hope next version of netscape will solve this.
OS : windows 2000 Server . Netscpe 7.2
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.7.2) Gecko/20040804 Netscape/7.2 (ax)
Sachin
sachinonnet
Postby robertb » Wed 29 Dec, 2004 6:16 am
Faced with a similar problem (OSX10.1.5 on a rather old iMac, Netscape7.2, Java applets not working), I tried Alice's solution - and it works with Yahoo Games :) but fails with message "Start: applet not initialized." on our banking login screen :(.
Is this a well-known problem? (IE gives a similar message in the same situation, which suggests to my naive mind that the problem may be in MRJ, or in OSX 10.1.5)?
Any advice would be greatly appreciated!
UserAgent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.7.3) Gecko/20041020
robertb
Postby Al » Wed 29 Dec, 2004 2:07 pm
It could be that banking site requires MS's VM which is only available on Wineblows. Your best bet is to get VPC or get a PC.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.5) Gecko/20041108 Firefox/1.0
Al
Who made Netscap 7.2?
Postby PW » Sat 15 Jan, 2005 6:14 am
I have read on http://ilias.ca/netscape/bigpicture/ this: "The team running the Netscape.com portal were not very happy with AOL's decision to discontinue Netscape, since a good portion of their traffic is from clickthroughs using the Netscape software. As a result, they took it upon themselves to contract former Netscape developers to make 7.2, using the money from advertising space on netscape.com, thus bypassing the AOL product development team."
Can anyone confirm this or give some further info/details? Are there any "old" netscape people still employed?
PW
Return to Reference Centre
