Netscape 7.2 Released (User Report and Feedback)
Postby Don_HH2K » Tue 17 Aug, 2004 2:19 pm
Well, you can always install a later JRE manually. I'm guessing this is a comatibility issue.
IMO, Java is only used for applications and not interactive Web content anymore, that title belongs to Macromedia Flash and Shockwave.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; m18) Gecko/20000929 Netscape6/6.0
Postby Al » Tue 17 Aug, 2004 2:22 pm
I wonder what extra software they put in NS7.2 and what are their verisons
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7) Gecko/20040803 Firefox/0.9.3
Al
Postby Don_HH2K » Tue 17 Aug, 2004 2:27 pm
Al wrote:I wonder what extra software they put in NS7.2 and what are their verisons
Well, I'm guessing that would probably be Net2Phone, AOL on Desktop, Netscape ISP on Desktop, Desktop Weather, and Desktop Navigator. I guess I'll see when I install it.
Postby James » Tue 17 Aug, 2004 2:41 pm
What is the point of having a Pop-Up Blocker in the new Netscape toolbar when the Pop-Up Blocker is already contained within the Preferences? :?
Postby Andrew T. » Tue 17 Aug, 2004 2:46 pm
My impressions of Netscape 7.2:
First of all, it is essentially what I had expected it to be; which is to say a relabeled version of Mozilla 1.7 with extra odds and ends. I have been using Mozilla 1.7 for three months (since it was in Release Candidate form), so I find no surprises with Netscape 7.2's major features or rendering capability. My comments concentrate on the features in Netscape 7.2 not present in Mozilla.
One of my favorite proprietary features of Netscape is the integrated Instant Messanger accessory in the sidebar. It has changed appearance slightly since Netscape 7.02 (the last Netscape release I used extensively), but otherwise offers what I expected it to. It is capable of connecting to either the AIM or ICQ networks (although not both at the same time), and is a convenient feature, although it is slightly more limited in features than the standalone AIM or ICQ applications.
The Netscape Toolbar is the most obvious new feature at first glance. I personally find it to be of marginal use, although I think it's an interesting feature and I am extremely glad that this Netscape accessory is finally available for the browser of the same name!
I was disappointed that Netscape was the only search engine provided in the integrated Search facility by default; a quick visit to Mycroft at mozdev.org allowed me to restore Google and other engines to the list.
Netscape ships with some third-party software, specifically "Desktop Weather by The Weather Channel," McAfee Clinic Activator, and Flash and Java plugins. I didn't install any of these; as I already had Flash and Java installed and didn't want the other two. I haven't seen any sign of the infamous Desktop Navigator as of yet...
UserAgent: Mozilla/5.0 (Windows; U; Win95; en-US; rv:1.7.2) Gecko/20040804 Netscape/7.2 (ax)
Andrew T.
Postby Al » Tue 17 Aug, 2004 2:47 pm
Maybe the toolbar's is for newbies
Al
Postby Don_HH2K » Tue 17 Aug, 2004 3:10 pm
Al wrote:Maybe the toolbar's is for newbies
No, I'm guessing that just turns it on and off via the toolbar, much like Prefbar.
I noticed something with NS front page just now. I mentioned before that I didn't get an Upgrade NS prompt, now I get a Switch to Netscape prompt. it appears that if you use a version of Netscape 7 earlier than 7.2 you get the Upgrade prompt, if you are using another browser such as Netscape 6 or earlier, Mozilla (maybe) or Ie, you will get the Switch prompt.
Postby Al » Tue 17 Aug, 2004 3:17 pm
I get it in Firefox, so that means Mozilla too
Al
Postby Don_HH2K » Tue 17 Aug, 2004 3:22 pm
Al wrote:I get it in Firefox, so that means Mozilla too
Well, I'll give AOL credit.
Netscape Network is the default portal for AOL Instant Messenger, many many people use that. If they're using it with IE (which I'm guessing they would be) at least they would be able to consider upgrading, since Netscape (the browser) was only listed as a small block of text on Netscape (the portal).
I never thought I'd say this since 1998, but good job to AOL, for promoting Netscape as a browser and not a portal.
Postby neonrich » Tue 17 Aug, 2004 3:44 pm
I have a few themes installed in my NS7.1 at home, I'm thinking I should remove them before running the NS7.2 install, correct?
neonrich
Postby Don_HH2K » Tue 17 Aug, 2004 3:46 pm
neonrich wrote:I have a few themes installed in my NS7.1 at home, I'm thinking I should remove them before running the NS7.2 install, correct?
If they're in your profile, yes. If they're in the install directory, the installer will do that automatically.
Postby neonrich » Tue 17 Aug, 2004 3:51 pm
Great, thanks. I'll be sure to double check the profile.
neonrich
Postby orizng » Tue 17 Aug, 2004 3:54 pm
this new Netscape bar is really not so good.
1. every search performed from this bar will use netscape search, which doesnt support language other than english
2.counting the blocked pop-ups looks fine, except it shows a deeper blue color when activated, which looks not so good.
3.too many bars make the interface crowded, i couldnt show netscape bar and personal tool bar together in order to get enough space for browsing.
Whatever,whatever,have a nice day.
orizng
Postby orizng » Tue 17 Aug, 2004 3:55 pm
i think its ok even if they are in profile folder.
orizng
Postby Wellander » Tue 17 Aug, 2004 4:36 pm
Did it curropt any ones else file system in Windows 2000?
I had to reinstall 2000.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.7.2) Gecko/20040803
Wellander
Return to Reference Centre
Registered users: Alexa [Bot], Google [Bot], MSNbot Media, Yahoo [Bot]
