16 bit version3.04
16 bit version3.04
Postby tomm » Sat 21 Aug, 2004 7:10 pm
I would like to install a 16 bit version of netscape on an old laptop running on windows 3.1 that only has a floppy. The file is 2.93 meg which will not fit on a floppy. how can I put it on multiple foppies or is there another way to download it over a modem ?
Please help
tomm
Postby Al » Sat 21 Aug, 2004 7:22 pm
Try zipping NS3.04, then extract it on your Win3.1 laptop
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7) Gecko/20040803 Firefox/0.9.3
Al
Postby tomm » Sat 21 Aug, 2004 8:14 pm
I tried but it is already a zipped file. I unzipped it and could send all but the data file to floppies . I tried to zip that file sepratly but it also is a zipped file.
Any other ideas?
tomm
Postby tomm » Sat 21 Aug, 2004 8:20 pm
Is there any other 16 bit version that is downladable onto multiple floppies? I amsure that origionally this version came on multiple floppies.
Thanks
tomm
Postby Al » Sat 21 Aug, 2004 8:22 pm
tomm wrote:Is there any other 16 bit version that is downladable onto multiple floppies? I amsure that origionally this version came on multiple floppies.
Thanks
Try NS 2.0 or lower then download NS3.04 or 4.08 onto the PC, or just zip the zipped file until it's less than 1.44 mb
Al
Postby Z_God » Sat 21 Aug, 2004 8:56 pm
When you compress it, make sure the parts you create aren't bigger than 1440 kB.
UserAgent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.7.2) Gecko/20040805 Netscape/7.2
Z_God
Postby Andrew T. » Sat 21 Aug, 2004 8:57 pm
Thanks
I believe Netscape hasn't been small enough to fit onto a floppy disk since before version 2.0. I believe the best procedure for getting Netscape onto this computer will be to use a utility like WinZip to further compress the browser's install file and, utilizing options, span it over several disks.
UserAgent: Mozilla/5.0 (Windows; U; Win95; en-US; rv:1.7.2) Gecko/20040804 Netscape/7.2 (ax)
Andrew T.
Postby tomm » Sat 21 Aug, 2004 9:02 pm
I just got the 2.0 file which I will install. Is there an install guide online?
tomm
Postby Wellander » Sat 21 Aug, 2004 9:04 pm
You can follow the directions on your monitor.
http://wp.netscape.com/eng/mozilla/2.0/ ... s-2.0.html relasese notes.
UserAgent: Mozilla/4.0 (compatible; MSIE 5.0; Windows 98; DigExt)
Wellander
Postby Antony » Sun 22 Aug, 2004 5:51 am
tomm,
Don't listen to Al.
you can't keep zipping. the file size won't get smaller.
:arrow: Follow Andrew's suggestion. The way to do is to use split the zipped files (span disc)
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us) AppleWebKit/125.4 (KHTML, like Gecko) Safari/125.9
Postby Josh » Sun 22 Aug, 2004 5:59 am
Al and Wellander:
The gentleman who posted here wanted to put 3.04 on his laptop using floppies. He does not want it zipped, as 3.04 zipped wouldn't fit a floppy.
Please stop SPAMMING this forum with useless tech postings! Read, them speak.
OK?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.7.2) Gecko/20040804 Netscape/7.2
Josh
SD701 Moderator
Josh
Postby tomm » Sun 22 Aug, 2004 8:44 pm
:) thank you very much for your assistance. I was able to load 2.0 . Tomorrow I will find out from my ISP wat the dial-up number was . I have not used it in years. I am sure that I will need to supply my username and password when logging on to my ISP. How can this be done with version 2.0 i have not found any such options?
Thanks Again
Tom
tomm
Postby Josh » Mon 23 Aug, 2004 2:01 am
Tom,
If you still want 3.04 on your Win 3.1 laptop, do this:
If you have a desktop computer that runs Windows 95 and later go to this website:
http://www.geocities.com/roverjbh99/16bitns3/
This site has the Win 3.1 version of NS 3.04 in three parts. Download each of the three parts and put them on three floppies. The files should fit on standard 1.44 MB floppies.
Go to to this site: http://www.freebyte.com/hjsplit/#classic
There you will find a program called HJSpilt. This program will put together the three files you have put on the floppies. Put this on the Win 3.1 laptop.
You will need to unzip the three files on the floppies with an ZIP program. I 'm not sure if there are any Win 3.1 programs left that do ZIP.
Once the files are unzipped, HJSplit has an option that joins spilt files. Choose this option. Pick the file:
n16d304.exe.001
Press OK.
After you are done, you should be left with the file:
n16d304.exe
Run this in the normal way. You will need to uninstall NS 2.02 first.
After you are done, you can delete the three files you got off the floppies and uninstall HJSpilt in you wish.
Happy Browsing!
Josh
SD701 Moderator
Josh
Return to Communicator
