Okay, so I am having various clients come to me with the same problems....they are not able to open attachments using their IMAPI netscape 7.1 mail setup. These users are forced to save to their desktop, then open up the files (like word docs, pdf, etc). They have been used to just being able to double click on the the file in the attachment box, and have netscape automatically open the helper application associated with the file. I have tried everything I know from reading the help files, but netscape will not open the attachment at all. I have tried putting new MIME types in the helper application preferences, I have removed, then replaced them, I have made sure that they had the right settings for everything (not viewing attachments inline), but still nothing....whenever the user clicks on the attachment, nothing at all happens....even when right clicking, and selecting open, netscape does not find the application to open any documents at all...it's like it doesn't even try to find the application...
Is there any way to fix this? I have upgraded machines from 7.01 to 7.1, and it still didn't fix the problem. Is there anything like a master reset to get all the default preferences back, and start from scratch? Has anyone had the same problem? It's happened on multiple machines here at work, even with updated office xp, winxp, sp2. Would upgrading to 7.2 solve this problem?
Please help...it would be greatly appreciated...thanks...
