Antony wrote:Expensive setup box or expensive new HDTV.DJGM wrote:Digital Terrestrial Television . . .
Digital Terrestrial Television (DTT) is not expensive. I don't know how much it costs in Australia,
but in the UK, we have a DTT service known as Freeview. To get this service, you purchase a
small set top box from about £40 from most high street electrical retailers, and get 30 extra
channels of TV and radio services, all without the need to pay any subscription fees.
I don't require an ugly satellite dish bolted to the side of your house as you'd expect if you
subscribe to Sky Digital, nor does it require the possibilty of your front lawn being dug up
to lay new fibre optic cabling, to receive digital cable services from NTL or Telewest.
You simply plug in the existing RF cable from your rooftop TV aerial that would normally be
plugged into the back of your TV set, into the DTT box, then one additional RF cable from
the DTT box, to the back of your TV set. This method of receiving digital television is also
portable, as the DTT box can be connected up to any suitable telly in any room.
For better picture and sound quality, it's generally recommended to use a SCART lead
connection from the DTT box to the telly, instead of the old fashioned RF connection.
The only way DTT can be expensive, is if you purchase an integrated digital TV set, which
has the set top box technology built in, so there's no need to purchase a seperate box.
These IDTV sets are usually widescreen, and can cost a few hundred pounds each.
Earlier this year, an extra DTT service started in the UK called Top Up TV. This offers all
the existing Freeview services, plus a few extra channels, all for £8 per month. Unlike
other subscription based TV services, there is no 12 month minimum contract, so if
you don't like what's on offer, you can phone up and cancel, and you're not stuck
with paying a years worth of monthly subs for something you don't want!
