The B+W G3 arrived earlier today, and despite a few scuff marks on the large Apple logos
on the side panels, and a few years of general wear and tear, this machine's a beaut!
I'll post a couple of pics later.
Here's my progress with this new acquisition so far . . . I've transplanted the 10GB HDD
that I've been using in the beige Power Macintosh G3 minitower, and all of the RAM.
Already, I'm experiencing a couple of problems. One is probably just a fairly moderate
problem, or it could well be quite serious. The other problem, is just plain annoying.
Firstly, Mac OS X won't start up. Or at least it's trying to start, but pretty much getting
nowhere fast. I've managed to get it to reboot in "verbose" mode, which displays all
the kernel startup messages that are usually kept hidden by the Apple boot screen.
After a short while, a numerous lines of UNIX type stuff that makes very little sense
to me, it repeatedly displays the message "jnl: flushing fs disk buffer returned 0x5".
I'll try "Verify/Reapir Disk Permissions" using Disk Utility, and see if that helps.
The annoying problem loes within Mac OS 9.x. Since Mac OS X has rendered itself
out of bounds for the time being, I'm using Mac OS 9.x as a temporary fallback.
Basically, every time I try to browse the web, the browser crashes. This isn't
just with one browser, it's all of them! Netscape 7.02, iCab 3.0, MSIE5.1 . . .
Every browser just "unexpectedly quits" with errors of either type 7 or type 2.
Whatever happens with this HDD, whether these ailments are cured or not, I'll soon
be installing a 20GB HDD, and reinstalling Mac OS X 10.3.x afresh. Eventually, a DVD
drive will replace the CD-ROM drive so that Mac OS X 10.4.x can be installed.
What's good about this particular machine, is that (AFAIK) it should be very easy for
it to accomodate two HDD's, so a 20GB HDD can become the main HDD, while the
aforementioned 10GB HDD can become the secondary HDD.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8b4) Gecko/20050715 SeaMonkey/1.0a
