"Sending of Password Did Not Succeed"
Postby Mike of Sheffield » Sun 26 Dec, 2004 6:42 pm
I've been using Mozilla successfully since v1.0, and have been on Moz 1.7.2 since its release.
Tonight when I load up, and go to email, I get the message
"sending of password did not succeed. Mail server responded 'maildir : permission denied'."
I have not altered any of my passwords (or any other settings) since last successfully loading Mozilla. Having checked, I confirm that Password Manager (under Mozilla Edit - Preferences - Privacy&Security - Passwords) still shows the correct passwords.
I'm running Moz 1.7.2 and Windows XP Pro (no SP2) with Norton AV 93 and Kerio Personal Firewall, connecting via 1Mb broadband. I use POP email. This combination has never caused a problem in the past - all components have been in place for months.
I have just confirmed that I can still *send* email - but I can't access any 'new' mail sent (other than that already received and so in my folder).
Anyone any bright ideas?? :o
Mike of Sheffield.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.2) Gecko/20040803
Mike of Sheffield
Postby Fulvio » Sun 26 Dec, 2004 10:42 pm
I don't know if they are bright idea, but it nothing has benn changed, and it would work ok, I would disable Norton.
Are you aware of the profile location?
Then delete the Inbox.msf file of your mail acccount, with Mozilla open.
No matter what this may be the golden opportunity to get Mozilla1.7.5. You should uninstall the older version. You can use the same profile, but I would recommend creating a new profile.
I would start minimally, setting up the account, and just testing incoming mail.
Postby Mike of Sheffield » Mon 27 Dec, 2004 7:10 pm
My ISP has now posted details of a widespread fault on their email servers which I suspect is the origin of my problem.
Thanks for your help though!
Mike of Sheffield
Mike of Sheffield
Postby Fulvio » Mon 27 Dec, 2004 8:48 pm
Mike,
how is it working at the webmail site? Anyway, I hope that they fix the problem.
Postby Mike of Sheffield » Sat 01 Jan, 2005 5:34 am
Issue at the ISP is now sorted and all email (AFAIK) has been delivered.
Thanks for everyone's helpful comments. I intend to try Moz 1.7.5 soon.
Mike of Sheffield.
Mike of Sheffield
