by Fulvio » Sun 09 Jan, 2005 4:33 pm
Accuradio? Icebergradio works, and it requires a minimum of WMP7.1. It is listed in their specs. But, I know that it works with WMP9 or 10, but I have had to fake the User Agent to Firefox. I reported to them, and, in exchange I got a newsletter. You should get that active X file out of the Firefox plugin folder. First of all it is necessary to have a proper file for each type of program, secondly, with the exception of Flash you don't need files in Firefox. And, thirdly you don't need Active X for the site I mentioned. Where do you get the idea?.
It may work work with WMP6.4, but this is what they say at their site.
If you are using Windows Media Player 6.4
Open Windows Media Player and select Tools|Options from the file menu. Click on the "Advanced" tab and press the "Change" button. The following dialog box appears. Make sure that the "HTTP" checkbox is selected. If your network administrator has configured your workstation, then select the "Use browser proxy settings" option, or you can contact your network administrator to manually configure the proxy settings after selecting the "Use proxy" option.
