PrefBar 3.0 Out
PrefBar 3.0 Out
Postby profman » Tue 04 Jan, 2005 10:25 pm
Version 3.0 of Prefbar was released on 2004-12-26.
The original preferences toolbar was designed to give the user more control over the pages viewed, and to allow the power browser to use mozilla with greater ease and efficiency than ever before. The PrefBar2 takes this concept to a whole new level; along with the standard preference checkboxes, the new version includes utility buttons, user agent spoofing, web links, and more, served on a fully customizable toolbar with a side of white rice.
The current version of the PrefBar is 3.0, build 20041224. It should work with Mozilla 1.0 to 1.7.5 and Firefox 1.0+.
The changelog for version 3 is
Changelog 3.0
* Finally fixed Bug 7702 "prefbar broken on Suse 9.x w/Moz 1.7.2/1.7.3" (Manuel Reimer)
* It's now possible to disable the display of PrefBar in Popup windows (Manuel Reimer)
* Rewrote whole rendering Code to make menus possible (Manuel Reimer)
* Overflow Menu for PrefBar (now Buttons not longer disappear) (Manuel Reimer)
* PrefBar Menu (full PrefBar functionality even without Toolbar) (Manuel Reimer)
* Drag and Drop Support in the Preferences Window! (Manuel Reimer)
* The Updater now not longer overwrites your self-defined button labels (Manuel Reimer)
* UserAgent now also gets resettet if you close Mozilla with File->Exit (Manuel Reimer)
* New Preferences Window for Firefox (now I not longer have to manage two preferences systems) (Karsten Düsterloh, Manuel Reimer)
* Reset-Button in Preferences Dialog (Manuel Reimer)
* New Buttons:
o Resize Menulist (Manuel Reimer)
o Clear Cookies (Manuel Reimer)
o Save Page (Manuel Reimer)
* The Buttons "Size 640x480", "Size 800x600" and "Size 1024x768" have been removed as they are replaced with the Resize Menulist (Manuel Reimer)
I have installed PrefBar 3.0 on Mozilla 1.7.5 on two systems running Windows XP. It, so far, seems to work OK. On the one system where it is installed under the profile (instead of under the program directory), the "What's New" button does not seem to work.
A couple of links (among many) to PrefBar threads at SillyDog are
PrefBar 2.3 Final Out
prefbar for Firefox PR 1.0
Postby Fulvio » Wed 05 Jan, 2005 12:35 am
Thanks. and, to anyone else, don't try the trick from the Netscape Browser.
And, best of all, download the .xpi file, and use it for everything you have.
The update is so smooth that it is almost scary.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.5) Gecko/20041107 Firefox/1.0
Postby James » Wed 05 Jan, 2005 10:38 am
I can't seem to download it at all. When I click on the download button (or the install entire package button) nothing happens. This is not very user-friendly.
Postby Fulvio » Wed 05 Jan, 2005 11:38 am
I find it quite easy to deal with, except that it is a two step operation.
1. http://prefbar.mozdev.org/installation.html
2. dowmload the .xpi file.
If I work with the .xpi file, which I download to the Desktop, I can drag and drop it on top of the desired shortcut. It has the effect of opening the program, and, then the installation begins. Restart the program, and you are done.
Why do I do this? First of all, it works. Secondly, I use one .xpi download, and I do the same operation with NS7.2, Moz1.7.5 and FF1.0, saving me the bother of hunting for the site.. And, I can use the same file for anything else which I may want to use at a later date.
It is unbelievaly smooth. I am asked if I want to update the buttons, before opening the program, and that's about it.
Postby James » Wed 05 Jan, 2005 12:11 pm
For some inexplicable reason it will not work for me. I've followed the directions and tried downloading the xpi file but no joy.
Note, threads merged.
Postby Fulvio » Wed 05 Jan, 2005 1:40 pm
I am in AOL9.0, where things are often pretty weird, and I found out that I could left click, and save to the AOL Download folder. Or, right click, Save Target as. This way I am presented with the run-of-the-mill Windows box, where I can select a download location.
I have not tried direct installation.
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; AOL 9.0; Windows NT 5.1; BCD2000; .NET CLR 1.1.4322)
Postby Al » Wed 05 Jan, 2005 6:36 pm
I have it Firefox, and it's useful, the last time i used it, it was on Moz 1.0
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.5) Gecko/20041108 Firefox/1.0
Al
Postby Gregor » Thu 06 Jan, 2005 7:41 am
It would be nice if Firefox will be capable to autoupdate it itself. That does`t seem to work.
Old Prefbar uninstalled manually and version 3 installed without problems.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; sl-SI; rv:1.7.5) Gecko/20041108 Firefox/1.0 (Netscaped)
"We don't receive wisdom; we must discover it for ourselves after a journey that no one can take us or spare us." Marcel Proust.
Gregor
Postby Mandrake » Thu 06 Jan, 2005 8:18 am
Excellent.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8a6) Gecko/20050101 Firefox/1.0+
success
Postby James » Thu 06 Jan, 2005 8:55 am
Success. Fulvio, I tried your method and it worked. Thanks.
Success with Prefbar 3.0 installation
Postby Fulvio » Thu 06 Jan, 2005 11:03 am
Great! I don't even remember if I read about it somewhere, or it was discovered by mistake. I am pretty sure that I was dragging the .xpi file which shows up in the bottom left corner to another folder, for storage, and I let go too soon. It was a Netscape7.x, and it opened Netscape, and asked me to Install or Cancel. what could I say?
Postby Al » Thu 06 Jan, 2005 6:44 pm
Gregor wrote:It would be nice if Firefox will be capable to autoupdate it itself. That does`t seem to work.
That is because of the extension number difference, if the number remained the same it would do that and uninstall the old one and add the new verison
Al
Postby James » Fri 07 Jan, 2005 1:15 am
Moderator: I apologize for starting a new thread. I meant to reply to a thread Profman had started about the Prefbar. If you want to either delete this thread or move it, I completely understand. Sorry.
Postby Fulvio » Fri 07 Jan, 2005 11:15 am
James,
no objection to your new thread. However, a word a caution. Your subject would have been enough for removal from the newsgrop, at other sites. At you site, the thread was sunmmarilily closed, with no second chance given. You know, those typical subjects like: Netscape 7.2.
I know that you know better, but make sure that you give some description. Many people by-pass poorly described posts.
In any event, I am happy to help.
Postby Antony » Fri 07 Jan, 2005 7:11 pm
James,
Don't worry. We are a friendly community. However, we do appreciate a descriptive subject (title).
I do understand that sometimes people click the wrong button instead. I've been working on the some adjustment to avoid confusing.
I will merge or move this thread later, when I have time.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/125.5.5 (KHTML, like Gecko) Safari/125.12
Registered users: Alexa [Bot], Google [Bot]
