Netscape Prototype 2 - available
Postby Antony » Fri 07 Jan, 2005 10:16 am
This is the continuum of the [sdt=7562]Netscape Browser Prototype[/sdt] thread. We started a new thread to make posting easier on the Prototype 2.
Netscape Prototype 2 is now available from Netscape Browser Review programme.
Netscape Browser Prototype will be based on Firefox 1.0, instead of previous Netscape Prototype based on Firefox 0.9.4. According to Netscape Product Manager, only the code base was changed.
Original thread, [sdt=7562]Netscape Browser Prototype[/sdt], is still available for archiving purpose.
changed to normal post, please use [sdt=8332]Netscape 8 pre-Beta[/sdt] to continue our discussion. 18 Feb 2005
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.7.5) Gecko/20050101 Firefox/0.6.4
Postby Antony » Fri 07 Jan, 2005 10:32 am
Joji [sdp=50666]announced it[/sdp] one step before me, (Virtual PC is not that fast.) Thanks Joji.
The new Netscape Prototype 2 contains a few performance improvements.
ATTENTION It is highly recommended that you uninstall and delete your existing Netscape Browser profile.  You can find your profile in the "Application Data" directory, which is typically found at  [tt]C:\Documents and Settings\\Application Data\Netscape[/tt].  The folder "Application Data" is hidden on many systems, and it can be unhidden by changing "Folder Options" in the "Tools" menu of Windows File Explorer.
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/125.5.5 (KHTML, like Gecko) Safari/125.12
Postby Antony » Fri 07 Jan, 2005 10:49 am
I do feel quite a bit faster in this Prototype 2 compared to previous Prototype, at least, the screen response is better. Perhaps, it was that I am running it under Virtual PC.
Postby localhost » Fri 07 Jan, 2005 11:02 am
downloading.... :P
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.5) Gecko/20041107 Firefox/1.0
--People who say it can't be done, should not interrupt those who are doing it.--
localhost
Postby Antony » Fri 07 Jan, 2005 11:08 am
As for the "blue" new theme (proposed), it won't be happen until the next release, methinks.
Home is not the same
Postby Roy » Fri 07 Jan, 2005 12:17 pm
My install has defaulted the "home" to:
[tt]http://home.netscape.com/bookmark/7_2/home.html
|http://channels.netscape.com/ns/browsers/browsing.jsp#br2[/tt]
which is currently timing out and when it did work seems to be the home for the Netscape 7.2 browser.
Prior to installing I removed all old folders and profiles.
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; DI60SP1001)
Roy
No changes in this version
Postby Roy » Fri 07 Jan, 2005 12:19 pm
They did mention that this version would have no design changes except for the use of the FireFox 1.0 release code.
Probably want to make sure it works the "same" before attempting any changes.
Roy
Postby Fulvio » Fri 07 Jan, 2005 2:00 pm
Since the Theme was the last of my concern, the first concern was with those stupid tabs. I have yet to figure out why the Tab controls are the way they are, I finally unchecked the "load in the background", and, I can finally can open a window. I would expect to open a window and create a Tab, not just the latter.
But, I am getting ahead of myself. I wanted to bring my Personal Toolbar folder, after kicking out all the extras, and I did the usual selection as Personal Toolbar folder, to no avail. I, finally, saw in the navigational customization, two bookmarks items. I dragged and dropped the "Bookmarks Toolbar Items", and I got what I wanted. The Tabs showed up as usual from my saved Tabs. And, Mail is fine, opening TB.
At this point I am almost ok, except for the single entry in downloads, of Windows Media .wmv files to open with AOL Communicator Media Player, which I don't have. So, I removed the item, just in case.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.5) Gecko/20050101 Firefox/0.6.4
Postby localhost » Sat 08 Jan, 2005 4:12 am
Just a short impression from me, as this is the first netscape preview I try. I skipped the first one.
I haven't payed too much attention to all the news that came after the first release. Except for the double browsing engine they use inside netscape. I must say I hope there will be a bugfix to get this insane idea out of Netscape. I like to use a browser that doesn't use the IE engine as I find this engine to be one major security risk. By giving the 'normal' user a incorrect idea of a trustable browser, the risk of infection is higher.
Second is the theme. UGLY. SillyDog mentioned the looks of the browser will get a faselift later on the development, but man this is terrible. Please give me some kind of seperators or something to show what parts belong to each other. And why is the menu aligned to the right side? I'm using Windows, Windows has a default, use the default.
I got some other points on the interfase, but I will get to them after they change they start working on it.
The pop Up blocker is way too difficult to use for an averedge user.
How do I add a bookmark that opens in de sidebar? The classic add to sidebar javascript doesn't work and the bookmark properties don't have the needed option. Even worse, where's my bookmarks toolbar? I don't want the sidebar to show my bookmarks, I want sidebar pages to show in there.
When I'm on a page and I want a new tab, I'll hit ctrl-enter (or some icon). This new tab should NOT show the same page I was on when I requested the tab. This is an inlogical feature comming from IE. This slows down the browsing, slows down the opening of a new tab.
Well, that will be the first I have to say about this. There will be lots of great features in this browser I didn't talk about, but that's not what's important at this moment.
localhost
Postby Al » Sat 08 Jan, 2005 8:39 pm
Proto 1 seems to be useless now, I still have it, mostly everything doesn't work
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.5) Gecko/20041108 Firefox/1.0
Al
Can't download
Postby James » Sat 08 Jan, 2005 9:41 pm
For some reason the Compu server appears to always be down when I try to download. Is anyone else having this difficulty? Any tips?
Re: Can't download
Postby Antony » Sun 09 Jan, 2005 12:55 am
James wrote:Any tips?
Try again later :-)
Available to all?
Postby Edward » Sun 09 Jan, 2005 8:26 am
Is Prototype 2 available to new testers, or is it still a closed group?
(Sorry if this is off-topic...)
UserAgent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:1.7.5) Gecko/20041217
Re: Available to all?
Postby Antony » Sun 09 Jan, 2005 8:44 am
Edward wrote:Is Prototype 2 available to new testers, or is it still a closed group?
Well, MozInfo701 reported Netscape Browser Review programme with the registration code on 16th November. We received great interests on the discussion, and the [sdp=47927]registration ended[/sdp] few days after. Sorry, you missed out.
Postby Gregor » Mon 10 Jan, 2005 3:48 am
Stability & performance much improved.
Startup Bug seems to be resolved.
The following Extensions can not be installed / added:
- Prefbar 3.0
- Web Developer 0.8
Otherwise testing.......
"We don't receive wisdom; we must discover it for ourselves after a journey that no one can take us or spare us." Marcel Proust.
Gregor
Registered users: Amrad, Google [Bot]
