[FX] JTw : Firefox 010805 MMX [Trunk/Win32]
Postby jayfromtaiwan » Sat 08 Jan, 2005 10:47 pm
Alrighty Antony forced me to post something so ... yeah here it is
Firefox 010805 MMX
> Huh? MMX SSE SSE2? What the heck?
.... Just check this list for the list of processors.
SSE2 (Oxp GALFT SSE2):
# AMD Opteron
# AMD Athlon FX
# AMD Athlon 64
# Intel Xeon
# Intel Pentium M
# Intel Pentium 4
# Intel Celeron (1.7GHz - 2.8GHz)
SSE (Oxp GALFT SSE):
# AMD Athlon XP
# AMD Athlon MP
# AMD Sempron
# AMD Duron (1.0GHz - 1.8GHz)
# Intel Pentium 3
# Intel Celeron (533MHz - 1.4GHz
MMX (Oxp GALFT):
# AMD Athlon
# AMD K6-2
# Intel Pentium 2
# Intel Pentium Pro
# Intel Pentium
> How to *properly* test the experimental builds?
If you encounter any problems while testing my experimental builds, don't freak out, just follow the following steps:
- Identify the type of the problem. Is it memory leak? UI bug? Unusable features? Or crashes? et cetera
- If the problem is memory leak, report the problem to me immediately
- If the problem's feature- or UI-related, check the patch list first then report the problem with/and the probable cause.
- If the problem's a crash, it would really help if you can include the cause (dll, exe, whatever) in your report.
- If the you have other problems, use the report form and try to be clear as possible.
It is possible that some problems are codebase-related. If it is the case then I can't really do anything about it.
Oh and one more thing. b#tch and Complaning won't help a bit, i will just simply ignore you and everyone would just laugh at you for being a retard.
> Building Environment:
- Dell Inspiron 8200 (P4 1.6 Ghz, 256 Mb)
- server 2003 Version 5.2 (Build 3790.srv03_rtm.030324-2048)
- Visual Studio .NET 2005 codename Whidbey Beta 1
> Just-in-case files:
- http://pryan.org/firefox/jayfromtaiwan/msvcr80.dll --> VC8 dll
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.2; en-US; rv:1.8a6) Gecko/20050108 Firefox/1.0+ (JTw)
Firefox - Thunderbird - Seamonkey - Sunbird
GECKO POWER .......
jayfromtaiwan
Link : http://pryan.org/firefox/jayfromtaiwan/ ... 05-MMX.exe
Changes:
- O2 GL optimized
- stipe's two optimization changes
- Bug 213163 show bookmark URL over mouseover of bookmark toolbar item in status bar
- Bug 179845 Support dragging a link onto the New Tab / New Window toolbar button.
- Bug 264562 Find As You Type / FastFind opens unexpectedly when rapidly opening a new webpage in a new tab
- Bug 267150 Find As You Type should be disabled in about:config
- Bug 269712 typed letters in about:blank default to find as you type ...
- Bug 263346 find toolbar deforms page with relative-height frames so click on link doesn't always work
- Bug 260437 "Set as Wallpaper" changes wallpaper for all users (should not save in windows directory)
- Bug 275096 Page Info | Media | Save As button non-functional
- Bug 255934 urlbar favicon not updated on tab switch if site has favicon.ico instead of link
- Bug 240637 XPI Install (for installing extensions, themes) should have 'Cancel' as the default button
- Bug 272566 Security tab missing post-merge
GECKO POWER .......
jayfromtaiwan
Postby Antony » Sat 08 Jan, 2005 10:54 pm
I've just had a quick test on this "JayfromTaiwan" build.
Seems to me, [sdt=7991]Netscape Prototype 2[/sdt] is slightly faster than this build, but I could be wrong, as I am running in on Windows 2000 Pro under Virtual PC for Mac.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.8a6) Gecko/20050108 Firefox/1.0+ (JTw)
Postby Mandrake » Sun 09 Jan, 2005 6:21 pm
Intel Streaming SIMD Extensions (SSE / SSE2 / SSE3) comprise a set of extensions to the Intel x86 architecture that is designed to greatly enhance the performance of advanced media and communication applications.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8a6) Gecko/20050101 Firefox/1.0+
Postby Antony » Sun 09 Jan, 2005 8:32 pm
Mandrake wrote:Intel Streaming SIMD Extensions (SSE / SSE2 / SSE3) comprise a set of extensions to the Intel x86 architecture that is designed to greatly enhance the performance of advanced media and communication applications.
which means not available in Virtual PC?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/125.5.5 (KHTML, like Gecko) Safari/125.12
Postby Mandrake » Mon 10 Jan, 2005 12:23 am
In VMware for Windows and Linux and Virtual PC for Windows you should be able to use SSE extensions in a 'guest OS', provided the processor in the PC supports SSE.
Virtual PC for Mac is different, since Virtual PC for Mac has to emulate an x86 processor. I guess it would depend on whether or not the processor Virtual PC emulates supports SSE or not.
