Ramona wrote:Fulvio,
I'm using an older Version of Acrobat Reader: 5.1.0.2002091700. I had no problem accessing the page your referenced. What Version of the Reader do you use?
Curt wrote:If you install Netscape or Mozilla AFTER you already have Adobe Reader installed open Adobe Reader, click "Help" on the toolbar, then click "Detect and Repair." This will install the Adobe Reader plug-in in the Netscape "plugins" Program Files folder. The repair files that the Adobe Reader 6.0 uses for this are in C:\Windows\Cache\Adobe Reader 6.0.1\ENUBIG. <snip>
Alice wrote:I did read something about the "Repair" option... "Detect and Repair" is also available from the Adobe Reader 7.0 Help menu.
What known issues are there with the Acrobat plugin?
Using Adobe Reader 6.0 on Windows, you may encounter the following problems:<snip> * If you have not accepted the Adobe Reader EULA, you have to minimize your browser to see it.
| [SillyDog701 home] [Netscape] [download NS] [MozInfo701] [MacCentre701] [Feedback] [Search] [Sitemap] All messages posted in this forum do not necessarily represent SillyDog701. This forum is operated by Antony Shen. All rights reserved. Copyright Notice. Privacy Statement. |
