Activation
Activation
Postby Peter6218 » Wed 23 Feb, 2005 4:29 pm
Due to a total hard drive crash I've had to re-install Netscape 6.
Now every time I start the Computer I get this message.
"Couldn't reach activation"
How do I get rid of this ??
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:0.9.4.1) Gecko/20020508 Netscape6/6.2.3
Peter6218
Re: Activation
Postby Antony » Wed 23 Feb, 2005 5:38 pm
Peter6218 wrote:Due to a total hard drive crash I've had to re-install Netscape 6.
It that computer's (Windows') activation OR Netscape's activation?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/125.5.6 (KHTML, like Gecko) Safari/125.12
Postby DJGM » Wed 23 Feb, 2005 5:45 pm
It'll most likely be Netscape 6.2.3 trying to connect to the now defunct activation.netscape.com,
to process the Netscape browser registration usually prompted for after installation of Netscape.
The best thing to do would be to either upgrade to Netscape 7.2, or Mozilla Firefox instead.
UserAgent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.8b2) Gecko/20050219
Postby Andrew T. » Wed 23 Feb, 2005 5:48 pm
To disable the obsolete "activation" feature of Netscape 6.2.x, you can follow one of the three procedures listed in this SillyDog701 Knowledge Base article.
UserAgent: Mozilla/5.0 (Windows; U; Win95; en-US; rv:1.7.5) Gecko/20041107 Firefox/1.0
Andrew T.
Postby Peter6218 » Wed 23 Feb, 2005 6:00 pm
Thanks Andrew
We'll see what happens :D
Peter6218
Postby Peter6218 » Thu 24 Feb, 2005 12:43 pm
Andrew T. wrote:To disable the obsolete "activation" feature of Netscape 6.2.x, you can follow one of the three procedures listed in this SillyDog701 Knowledge Base article.
Ended up with the third option on the list. Worked perfectly
Thanks
Peterr
Peter6218
Postby Fulvio » Thu 24 Feb, 2005 1:05 pm
And, now, consider downloading a newer Netscape, uninstall the old one, and install the new one. Your mail and stuff will not be affected, although I havve no idea the transition will be smooth. The old version is very different from the new one.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.5) Gecko/20041107 Firefox/1.0 (ax)
Postby Peter6218 » Thu 24 Feb, 2005 1:11 pm
Fulvio wrote:And, now, consider downloading a newer Netscape, uninstall the old one, and install the new one. Your mail and stuff will not be affected, although I havve no idea the transition will be smooth. The old version is very different from the new one.
I prefer Ver 6, thanks.
I don't like the way ver 7 handles several functions including bookmarks. 6 is much simpler and works well. I had ver 7 running for a while and went back to 6.
Thanks anyway.
Peter
Peter6218
Postby Fulvio » Thu 24 Feb, 2005 1:19 pm
Handle bookmarks? Whatever!
Postby Peter6218 » Thu 24 Feb, 2005 1:25 pm
Fulvio wrote:Handle bookmarks? Whatever!
7 doesn't allow you to specify where the bookmark is to go when you create it. Pain in the ass
It doesn't do prefill forms nearly as nicely as 6. I do a lot of email of newspaper articles and the 6 method is far superior.
Want to see what ver 8 is like?
Peter6218
Postby Al » Thu 24 Feb, 2005 7:37 pm
Why not try Mozilla Firefox?
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.5) Gecko/20041108 Firefox/1.0
Al
Postby Peter6218 » Thu 24 Feb, 2005 7:39 pm
Al wrote:Why not try Mozilla Firefox?
I use that for certain sites where I have style sheet problems. Not bad but not Gecko
Peter
Peter6218
Postby Al » Thu 24 Feb, 2005 7:42 pm
Firefox is built on Gecko, and so is Netscape
Al
