Mozilla Questions
Mozilla Questions
Postby W.R. » Mon 29 Jul, 2002 4:20 am
When they ask u if u wanna install the debugger and personal security manager should u? do any of these features "Weigh down" Mozilla and make it slower?
W.R.
Postby Josh » Mon 29 Jul, 2002 4:35 am
Short Answer:
Debugger: NO
Personal Security Manager: YES
Long Answer:
The debugger is used by web developers to debug Javascript, as is the DOM (Document Object Model) Inspector. If you aren't a web developer, you can forget these. On the other hand, you do need the Personal Security Manager (PSM). If you don't have the PSM, that you cannot access URLs that begin with 'https' or do other things that need SSL (Secure Socket Layer). Does this two addons weigh Mozilla down? I'm inclined to say no. I've found Mozilla runs well with just Navigator, PSM, and that feedback thingy installed as would with the whole package installed. (I'm running Mozilla from the ZIP file, BTW.)
Josh
SD701 Moderator
Josh
Postby W.R. » Mon 29 Jul, 2002 7:40 am
Thanx Josh, 1.0 is great
W.R.
Postby Shark Daddy » Mon 29 Jul, 2002 9:12 pm
Very short: No, No.
Shark Daddy
Registered users: Fulvio, Google [Bot]
