Can't delete some Inbox subfolders!
Postby joe39 » Thu 17 Mar, 2005 1:49 pm
Hello Wise Ones,
I thoroughly enjoy your site - it is a wealth of information and one I depend on to keep my browser going. I use Netscape 7.2 and Windows XP Home but only yesterday, I tried to delete several subfolders from my inbox and it wouldn't take. The highlight would return to the Inbox folder. I also couldn't transfer any messages to any of these folders.
What to do?
Thanks,
Joe
joe39
Postby Ramona » Thu 17 Mar, 2005 2:08 pm
Joe,
Close Netscape and Quick Launch, open Windows Explorer and navigate to your Mail Account folder.
Open the Mail Account folder and delete the files with an MSF extension, e.g., Inbox.msf, Drafts.msf, etc. DO NOT DELETE the files WITHOUT the MSF extension, as they contain your Mail.
Post back if you continue to have problems.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.6) Gecko/20050223 Firefox/1.0.1
Postby joe39 » Thu 17 Mar, 2005 2:25 pm
[quote="Ramona"]Joe,
Ramona[/quote]
Ramona,
Where would I find these files?
Joe
joe39
Postby Ramona » Thu 17 Mar, 2005 3:15 pm
Joe,
Your files would be located here:
[tt]C:\Documents and Settings\user_name\Application Data\Mozilla\Profiles\profilename\*.slt\Mail[/tt]
NOTE: These files are hidden by default.
To see hidden files:
1. On the Tools menu in Windows Explorer, click Folder Options
2. Click the View tab
3. Under Hidden files and folders, click Show hidden files and folders
4. Disable "Hide File Extensions for Known Files."
5. Click OK.
Postby joe39 » Fri 18 Mar, 2005 12:18 pm
:) 8-) :wink:
Ramona,
Finally got around to doing what you said and it works just fine. Thanks for your excellent help.
Joe
joe39
Postby Ramona » Fri 18 Mar, 2005 1:28 pm
Always a pleasure, Joe! Thanks for posting back with your results.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.6) Gecko/20050317 Firefox/1.0.2
Postby joe39 » Mon 18 Jul, 2005 12:01 pm
Ramona,
The problem has raised its ugly head again. I deleted all the msf files and a search for *.msf reveals none. What can I do??
Thanks,
Joe :(
joe39
Postby joe39 » Mon 18 Jul, 2005 12:41 pm
Ramona,
Nevermind, I went into the files and found the specified folder. I deleted it and it is nomore in Netscape. Glad to have it gone.
Thanks,
Joe :)
joe39
Postby Ramona » Mon 18 Jul, 2005 12:47 pm
Joe,
I was just about to post the below, and I would still move the subfolders out of the Inbox, if they are large files.
Exit Netscape 7.2
Back up your Profiles folder
Next:
Delete the entire Cache folder
Delete the XUL.mfl file
Netscape will build these files and folders on Startup
Open your Inbox.sbd folder
You should see your subfolders listed there with the name of the folder, and it's .MSF file, e.g., Family, and Family.msf
Copy the file with NO MSF extension to your Mail Account folder in the left panel of Windows Explorer
Delete the MSF file
Do this for each subfolder
When you open Netscape Mail, you will see the subfolders listed under your Mail Account name, rather than the Inbox.
The Inbox is not intended for archiving, and if you have very large Mail files, this might, stress might, be your problem. At any rate, I would stop using subfolders for the Inbox, and instead make your subfolders under the Mail Account.
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.9) Gecko/20050711 Firefox/1.0.5
Postby Ramona » Mon 18 Jul, 2005 12:50 pm
To add one more detail, I would suggest that you move to Firefox and Thunderbird, or Mozilla 1.7.8, or else wait until the new Versions of all three, which should be out this week or next.
Netscape 7.2 is not as stable as the above browsers, not to mention the security vulnerabilities and bugs. I would give it some serious thought....
FWIW,
Postby joe39 » Mon 18 Jul, 2005 1:00 pm
Ramona,
Good idea (as usual). I wish the new Netscape 8.0 had an email program. A "Gal Pal" is also having some trouble with Netscape 7.2. I'll pass your suggestion on to her.
Thanks Again,
Joe
joe39
Postby Fulvio » Mon 18 Jul, 2005 1:18 pm
I agree with ramona about the vulnerabilities, which may or may be troublesome (other than to the mind), but I found NS7.2 mail to be as stable as any of the Mozillas, or Thunderbird, for that matter.
Unfortunately, many users are doing things which make sense (most of the time), but should not not be done, with such programs.
I am getting more and more disanchanted with their performance, often due to obscure or non-existing directions.
The way AOL has been handling NS, I am delighted that it does not have mail. for now there is only Thunderbird, and the new 1.1 will be dynamite.
For a day or two, of course, until vulnerabilities are unearthed.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.8) Gecko/20050511
Registered users: Google [Bot], James
