For anyone with orphaned Add/Remove entries they would like to remove, I copied the following from the firefox newsgroup at secnews.netscape.com:563
Subject:Re: *Mozilla Firefox 1.0.2 Released*
Date: Thu, 24 Mar 2005 17:11:24 -0500
Newsgroups: netscape.mozilla.firebird
<snip>
>>>>>>>>>> I did a Tools=>Update, which - wonder of wonders - installed 1.0.2.
>>>>>>>>>> I see the cautions against installing over 1.0.1, though. But I
>>>>>>>>>> don't seem to have any problem with the update so far. Does doing
>>>>>>>>>> it this way cause any problems that I just haven't seen yet?
>>>>>>>> The problem:
>>>>>>>> Windows Control Panel -> Add or Remove Programs.
>>>>>>>> There is more than one Firefox entry.
>>>>>> Ah, I see that now. Two questions then...
>>>>>> 1. Are two entries in Add/Remove really a problem?
>>>>>> 2. If it is a problem, would removing the old entry with TweakUI (XP
>>>>>> Powertoys) fix it, or are there other aspects (e.g. registry) to the
>>>>>> old Add/Remove entry that would remain?
>>>>>> Thanks, Kris
>>>> No the two entries are not really a problem, as long as you understand
>>>> why they are there. What does cause a problem is that new users
>>>> sometimes see the two entries weeks after installing a new version,
>>>> and will try to uninstall the older version. Since that older version
>>>> really isn't there, the current version is uninstalled instead.
>>>> This leaves the user with no working version, confused, angry, and
>>>> headed to Opera.
>>>> There are several way to remove the orphaned entries. I am sure
>>>> TweakUI could do it, Regcleaner can do, even Spybot S&D can do it.
>>>> Lee
>> Sorry. I guess I was thinking of Regcleaner. I don't see how to do it in
>> TweakUI. I'll try that.
>> Kris
Since most people have Spybot S&D aboard, its pretty easy in Advanced Mode.
In Spybot, at the left click Tools, then choose Uninstall Info. In the
list of programs scroll down to Mozilla Firefox 1.0, or whatever old
version you have listed. Click on it once to highlight, then click
Delete. Presto, the rogue listing is gone.
Lee
-- Leonidas Jones, Mozilla Champion
Note that TweakUI for Win9X will allow you to delete Add/Remove entries . The WinXp version doesn't include that feature.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.6) Gecko/20050319
