Prob #1 When I'm on my WebPage and I go to "edit", there are times that I cannot strike the keys hard enough to have the come up, it's almost as if the keyboard doesn't work (I already went and got another keyboard, same problem). I end up going to "WORD", typing what I need, then copy/paste them onto my edited page.
Then when I go to save, it just sits there, and many times, and error will come up (to send/don't send), then the browser will close and my stuff will not have been saved.
Prob #2 The past few days, when I've gone to add a web link, i'll "insert" it, type in "www.blahblahblah.com (e.g), then when I "save" and preview..it goes to a page with "ERROR" on it. when I check my link address, it will have added it to the file address of the webpage I was editing. e.g. f://sldjdjjdd/www.blahblahblah.com (sldj....& blahblahblah etc.. are just made up for example purposes)
I consider myself fairly computer illiterate, so please help! I've got two projects for this class I need to be working on!
thanks so much for your help.
UserAgent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; YPC 3.0.1; SV1; (R1 1.5))
