any help will be apppreciated.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.8) Gecko/20050511 Firefox/1.0.4
WARNING!! Before you begin, if you use the Adblock Extension, you must make sure that the setting for OBJ-TABS is disabled. Otherwise, your system will run almost any ActiveX control. See Note 4.
<snip>
Note 4. For some reason, the OBJ-TABS setting in the Adblock Extension interferes with the ActiveX plugin. The activex.js file that is installed with the plugin determines which controls the plugin may and may not run. If the OBJ-TABS setting is enabled, then the ActiveX plugin will ignore activex.js and run any control.
DiscoFever wrote:How is Active X when it comes to security? My wife Pays bill and makes credit card purchases via the Internet. Does this Active X cause any security risk. That is my main concern.
* The plugin for Firefox 1.0.3 does not come pre-configured to only run the WMP controls, so if you have Firefox 1.0.3 or 1.0.4 it is recommended that you edit activex.js and replace it with the text below to enable only Windows Media Player to run (unless you need to run other ActiveX controls). activex.js is located in the \defaults\pref\ subfolder of the Installation directory.
pref("general.useragent.vendorComment", "ax");
pref("security.xpconnect.activex.global.hosting_flags", 9);
pref("security.classID.allowByDefault", false);
pref("capability.policy.default.ClassID.CID6BF52A52-394A-11D3-B153-00C04F79FAA6", "AllAccess");
pref("capability.policy.default.ClassID.CID22D6F312-B0F6-11D0-94AB-0080C74C7E95", "AllAccess");
* When Installation is complete, restart Firefox.
| [SillyDog701 home] [Netscape] [download NS] [MozInfo701] [MacCentre701] [Feedback] [Search] [Sitemap] All messages posted in this forum do not necessarily represent SillyDog701. This forum is operated by Antony Shen. All rights reserved. Copyright Notice. Privacy Statement. |
