Acid Pro Software on Mac Os
Postby markwhiteside » Tue 19 Jul, 2005 11:45 am
i was wondering whether anyone had tried using Acid Pro software using Virtual PC on a mac os???
I'm just about to purchase a powerful G5 iMac and i need to know whether running Virtual PC on it will enable me to use Acid Pro music software!!
Any help appreciated...
thanks,
mark
markwhiteside
Postby Antony » Tue 19 Jul, 2005 9:40 pm
Hello markwhiteside,
do they have Acid Pro for Mac?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/412.6 (KHTML, like Gecko) Safari/412.2
Re: Acid Pro Software on Mac Os
Postby Mandrake » Tue 19 Jul, 2005 11:06 pm
markwhiteside wrote:i was wondering whether anyone had tried using Acid Pro software using Virtual PC on a mac os???
thanks,
mark
There is no version of Acid Pro for the Mac. The program would run, albeit very slowly, on Virtual PC.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.10) Gecko/20050716 Firefox/1.0.6
Postby markwhiteside » Wed 20 Jul, 2005 12:41 pm
hey cheers mandrake, as long as i can get it to work thats the main thing!!
is virtual pc the fastest/best software of its kind available do you know?
i've seen other kinds of software on the net but really know nothing of how they perform with programs such as Acid.
cheers again
markwhiteside
Postby Mandrake » Wed 20 Jul, 2005 8:41 pm
For the Mac Virtual PC is probably the best program. Though a huge program like Acid Pro is not going to run with acceptable performance under Virtual PC - it's only just going to run.
Postby Antony » Wed 20 Jul, 2005 10:49 pm
Hello again,
I assume you want to some music "creating" software, rather than "looping" software.
Other similar software are Logic Express (or the professional version, Logic Pro), Reason.
If you want a loop based software, I would suggest Soundtrack Pro
I use Soundtrack 1.2 myself.
Hope this helps.
Postby markwhiteside » Fri 22 Jul, 2005 4:48 pm
cheers for the feedback you guys... think i'm probably gonna get a pc with the minimum requirements aswell as the imac!!
too lazy to learn yet another music editor!!
acid is perfect for what i do.. its mainly loop editing and sequencing
cheers again :)
markwhiteside
