Netscape Browser 8.0.3.1 released
Postby J-M » Mon 25 Jul, 2005 1:33 pm
Download The Netscape Browser, v8.0.3.1:
http://browser.netscape.com/ns8/download/default.jsp
Download link (Windows version only) is totally same as earlier, pointing to http://ftp.netscape.com/pub/netscape8/e ... -setup.exe .
Nsb-setup.exe is dated as 25-Jul-2005 12:31 (281kB). The Full version is 13Mb.
From Security Alerts page at http://browser.netscape.com/ns8/security/alerts.jsp :
• MFSA 2005-56 Code execution through shared function objects
• MFSA 2005-53 Standalone applications can run arbitrary code through the browser
Only two fixed issues? :o :? :?
Juha-Matti
Edit: added quoting from Security Alerts page
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; fi-FI; rv:1.7.8) Gecko/20050511 Firefox/1.0.4
J-M
Postby TK19 » Mon 25 Jul, 2005 1:35 pm
weird, what about plain, old NS 8.0.3?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O; en-US; rv:1.7.10) Gecko/20050715 Firefox/1.0.6
I have no signature. :(
TK19
Postby Fulvio » Mon 25 Jul, 2005 1:53 pm
Are you serious? They are only numbers. You get what they give you, if you care.
Should anyone care, the link gives only the stub installer.
Everything else is cool. Not sure if other themes which worked in 8.0.2 will work. No big deal. Make sure to pay attention at all options on installation.
Skypilot works!
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.5) Gecko/20050720 Netscape/8.0.3.1
Postby Ramona » Mon 25 Jul, 2005 1:56 pm
J-M,
The Release Notes say this:
What's fixed in this version?
• Four critical security vulnerabilities (two can be found here [tt]http://browser.netscape.com/ns8/security/alerts.jsp[/tt],
and documentation for the other two will be released shortly)
• Fixed remaining history syncing issues between rendering engines
• Various bug and crash fixes
UserAgent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.7.10) Gecko/20050716 Firefox/1.0.6 (ax)
Postby J-M » Mon 25 Jul, 2005 2:03 pm
Ramona wrote:J-M,
Thanks for the quoting, I was just adding a reply :wink: and pointing to possible MFSA2005-47, -55 and -45 issues which are Critical according to Mozilla Foundation, and according to security companies handling 8.0.2 vulnerabilities.
Let's wait for additional information from America Online.
J-M
Postby J-M » Mon 25 Jul, 2005 2:19 pm
The User Agent string on Windows XP is very typical:
J-M
Postby J-M » Mon 25 Jul, 2005 2:39 pm
It seems that 'Firewalling' issue handled at http://www.mozilla.org/security/announc ... 05-47.html (Code execution via "Set as Wallpaper" i.e. Background) is fixed now.
J-M
Postby J-M » Mon 25 Jul, 2005 2:56 pm
< IMG > tag security check bypass vulnerability handled at http://www.mozilla.org/security/announc ... 05-55.html (XHTML node spoofing) is fixed now when tested recently.
J-M
Postby J-M » Mon 25 Jul, 2005 3:04 pm
Just tested JavaScript InstallVersion.compareTo() function vulnerability; http://www.mozilla.org/security/announc ... 05-50.html (Possibly exploitable crash in InstallVersion.compareTo) with Windows XP and 8.0.3.1 _WAS_ affected, the crash effect was just similar as with 8.0.2. :(
After that tested Content-generated events affecting browser UI vulnerability; http://sillydog.org/forum/viewtopic.php?t=9401 and http://www.mozilla.org/security/announc ... 05-45.html (Content-generated event vulnerabilities), rated as High risk:
version 8.0.3.1 WAS affected and Status Bar just went away.
Test link is located at here.
And finally, XBL Scripts JavaScript state bypass vulnerability: XBL scripts are still running. This is issue http://www.mozilla.org/security/announc ... 05-46.html (XBL scripts ran even when Javascript disabled).
J-M
Postby Antony » Mon 25 Jul, 2005 6:40 pm
what happened to Netscape 0.8.3 ?
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/412.6 (KHTML, like Gecko) Safari/412.2
Postby J-M » Mon 25 Jul, 2005 7:02 pm
Now Netscape has confirmed that they were fixing only two critical issues:
Netscape fixes browser flaws
Netscape 8.0.3.1 takes care of two flaws that were previously disclosed and fixed in Firefox, the open-source Web browser on which Netscape 8 is based, Netscape spokesman Andrew Weinstein said.
Ten less-serious flaws will be dealt with in another update due in the coming weeks, Weinstein said. "We wanted to make sure that we tackled the larger issues immediately," he said.
J-M
Postby Antony » Mon 25 Jul, 2005 7:52 pm
J-M wrote:Now Netscape has confirmed that they were fixing only two critical issues:
Netscape's Release Note (for 0.8.3.1) states:
Four critical security vulnerabilities (two can be found here http://browser.netscape.com/ns8/security/alerts.jsp, and documentation for the other two will be released shortly)
So the *less-serious* flaws will be updated shortly? That's good to know.
It's better to have serious flaws fixed now rather than leaving them unpatched for longer.
Postby Antony » Mon 25 Jul, 2005 8:53 pm
I just noticed this...
During the installation, the default theme is Netscape Winscape, was that in earlier version as well?
Is Netscape phasing out (slowly) the unique Fusion Theme?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.7.5) Gecko/20050720 Netscape/8.0.3.1
Postby Andrew T. » Mon 25 Jul, 2005 9:07 pm
Antony wrote:I just noticed this...
I believe the Winscape theme, as well as the option to use either it or "Fusion" when installing, has been present in Netscape 8.0 ever since the first non-beta release was available.
UserAgent: Mozilla/5.0 (Windows; U; Win95; en-US; rv:1.7.10) Gecko/20050716 Firefox/1.0.6
Andrew T.
Postby DJGM » Mon 25 Jul, 2005 9:34 pm
Maybe the Winscape theme is more popular, and they've made it the default owing to popular
demand. If so, that's the first wise move Netscape has made with the GUI on Netscape 8.x.x.
Let's face it . . . it does conform to proper standard UI conventions, and it is a darn sight
better looking than that total and utter dog's breakfast known as the Fusion theme!
Put it this way, if Netscape 8.x.x was available for Mac OS X (like it should be) would
the Fusion theme conform to the hallowed Apple Human Interface Guidelines at all?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.7.10) Gecko/20050717 Firefox/1.0.6
