nstmp folders, why?
nstmp folders, why?
Postby Fulvio » Sun 31 Jul, 2005 9:03 pm
I had this problem way back with a NS4.7, when a bunch of files showed up, in mail. At least, I think that this was happening, and I have no clue how I solved the problem. I think that I either created a new account or profile, and they never came back. But, I read of other people reporting this in NS7.x and Thunderbird. has anyone heard of this?
By the way, I thought that it was a n SMTP, but it is, rather ns tmp, Netscape temporary? Is it related to Google Desktop Search, or AntiVirus scanning?
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.10) Gecko/20050716 Thundershark/1.0.6
Postby profman » Sun 31 Jul, 2005 11:00 pm
(I apologize in advance for doing just a half-way Google search on this problem.)
The nstmp folders are mentioned on the internet in a couple of ways:
1. They are related to problems due to mail compaction and/or an overly large (over 2 GB) mailbox.
2. Some sort of interaction between a desktop search program (Google and Yahoo were mentioned) and Thunderbird mail creates these folders. I did not get enough on this to report.
References to #1:
Post at Mozillazine by umsken on Fri 4th Feb 2005 7:17pm. This post relates to Netscape 7.x.
A fixed MailNews bug: Bugzilla Bug 88515
Unconfirmed bug in Thunderbird: Bugzilla Bug 294654
Bonsai Comments:
2005-07-02 16:51 try to fix nstmp files appearing in pop3/local accounts after folder compaction, sr=mscott, a=asa, 8851588515
A now deleted long-ago posting that says:
Thread: nstmp
DATE: 01/29/2001 16:20:56
SUBJECT: RE: nstmp
Seth -- I was using the 1/18 build when this happened. I have since
updated to the 1/27 build which is much better :-) The 1/18 build would
crash on every compact folder attempt. So far, this build hasn't
crashed -- *period*!
I will, however, keep a watch for the nstmp folder to reappear again and
then see if I can duplicate the occurrence.
As always, thanks for your help.
Steve
Seth Spitzer wrote:
> Steve Carroll wrote:
> I've notices the automatic creation of a nstmp folder now and then
> --- sometimes it's empty, sometimes it has bunches of messages in
> it. The last time it appeared seemed to be folllowing a crash while
> trying to compact my inbox.
> Which build are you using? I think bienvenu fixed a crasher bug in
> folder compaction recently.
> when I restarted mozilla my inbox was EMPTY (oh no!) but the nstmp
> folder contained those files plus some other "junk" I'd deleted from
> the trash.
> If you can reproduce this with a recent build, can you start a bug and
> assign it to bienvenu?
> Is that the purpose of the nstmp folder? A kind of safeguard when
> performing potentially fatal operations like compacting, deleting or
> moving batches of files?
> From a quick glance at the code
> (http://lxr.mozilla.org/seamonkey/source ... pactor.cpp)
> it looks like we take the folder to compact, iterate over all the
> messages and create a temporary folder and temporary summary file.
> when we are done, if everything went ok, we over-write the uncompacted
> versions of the folder and the summary file with the compact version.
> -Seth
Hope this helps! It was beginning to give me another migraine. :wink:
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.11) Gecko/20050728
Postby profman » Thu 04 Aug, 2005 10:59 pm
I never thought that I would experience this problem, but I recently did.
After compacting a number of my "Inbox" and "Sent" mail folders in Mozilla 1.7.11, a number of these nstmp folders (and one nstmp-1 folder) appeared amongst my mail folders. I've had Google Desktop Search installed for quite some time and recently installed Copernic Desktop Search, so both were active during the compacting process. All the nstmp folders were perfectly readable copies of the inbox of the account. I deleted all the nstmp folders after I made sure that no mail was lost.
I have since uninstalled Google Desktop Search since I prefer the more customizable Copernic product. I may decide to shutdown Copernic's indexing service, or the whole program, before I compact my mail folders again. I've never set Mozilla to automatically compact, preferring instead to do it manually.
Postby Fulvio » Fri 05 Aug, 2005 10:38 am
The question was asked me by someone else, who could not see anything but the nstmp folders. It appeared that the normal Inbox was gone.
But, interestingly, I had just updated the Copernic Desktop Search, and wanted to do some looking around for odd files, after AVG reported one infection by Java/Openstream, a trojan. AVG, apparently, could not clean things up, but, I did it manually. And, I seem to be clean.Nothing had been activated. But, then, reading some items, after doing a search., I became paranoid, and, tried to use Copernic Desktop Search, but I did shut it off.
Should anyone care, the infected file was a javainstaller.zip. In that form it is no threat, but if unzipped it is.
Anyway, the more things one had, the greater the danger. CDS is going to sleep, for the time being.
UserAgent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.10) Gecko/20050716 Sunchameleon/1.0.6
Registered users: Google [Bot], Google Feedfetcher, Majestic-12 [Bot]
