Safari's HTML extension
Moderator: Don_HH2K
Postby Antony » Thu 18 Aug, 2005 1:16 am
from Apple's documentation, Safari HTML Reference Safari HTML Reference (also :pdf: PDF version)
Following HTML tags are supported.
<canvas>
<keygen>
<layer>
<marquee>
<nobr>
<noembed>
<nolayer>
<plaintext>
<wbr>
<video>
<xmp>
Yes, the <LAYER> is supported! I love Safari!
UserAgent: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/412.6.2 (KHTML, like Gecko) Safari/412.2.2
Postby Antony » Thu 18 Aug, 2005 1:41 am
Apple also has some excellent extensions to HTML attributes.
For example, Safari supports many different input types. They can be specified using the type attribute of the input element.
type="search"
Provides a search field. As well as incremental , placeholder , autosave , and results attributes in addition to standard HTML attributes to provide better Search box.
For example:
you can create this Apple Human Interface Guidelines complied search box in your website.
type="range"
Provides a slider. Its minimum value should be set with the min attribute, its maximum value should be set with max, and its discrete step size should be set with step.
